lre-oled-bar2
Differences
lre-oled-bar2 [2023/09/07 20:34] – [Building and BOM] phatline | lre-oled-bar2 [2023/09/12 14:20] – [Frontpanel] phatline | ||
Line 8: | Line 8: | ||
I didnt panalize it, so you have to do this when ordering the PCB online\\ | I didnt panalize it, so you have to do this when ordering the PCB online\\ | ||
you will need 4 PCBs per LRE8x2... normally you want to order 8 PCBs (using 2x LRE8x2)\\ | you will need 4 PCBs per LRE8x2... normally you want to order 8 PCBs (using 2x LRE8x2)\\ | ||
Here are the gerberfiles for production - i made it with[[https:// | Here are the gerberfiles for production - i made it with[[https:// | ||
- | {{: | + | These are the settings, if you want to V-Groove it you have to panalize it at 2x4 PCBs at one pcb. |
+ | the minimal order is 5 PCBs... so you may have then 4 sets left that you can sell or make a present for anyone...\\ | ||
+ | If you use EuroPacket as shipping method you will pay 26€ / thats incl import duty and taxes!\\ | ||
====== Hardware Requirements ====== | ====== Hardware Requirements ====== | ||
- | * [[http:// | + | * a[[http:// |
- | * [[DisplayDriver-SMD]] which buffers the Displays | + | * [[DisplayDriver-SMD]] which buffers the Displays, they are already assambled, and 5 pieces costs around 60€ - you only need 1 PCB here (60/ |
* Soldering Iron - with a Dip that can Handle Thruhole-Parts, | * Soldering Iron - with a Dip that can Handle Thruhole-Parts, | ||
* [[mb-lre8x2cs_pcb]] for its nature use\\ | * [[mb-lre8x2cs_pcb]] for its nature use\\ | ||
* [[LRE5-LCD2]] as UI to handle Patch management and automation (if you want to use my code...) | * [[LRE5-LCD2]] as UI to handle Patch management and automation (if you want to use my code...) | ||
+ | * You may need a [[http:// | ||
+ | * If you have not already - you will need a IDC-Crimper for all your Midibox Cables [[https:// | ||
====== Shematic ====== | ====== Shematic ====== | ||
Line 28: | Line 33: | ||
- | **Following Quantity is for 1 PCB (you may need this up to 8 times!:**\\ | + | **Following Quantity is for 1 PCB (you may need this up to 8 times!):**\\ |
2x 1Row 7Pin Male headers (2.54mm pitch) - normally delivered with the Displays!\\ | 2x 1Row 7Pin Male headers (2.54mm pitch) - normally delivered with the Displays!\\ | ||
- | 2x 8PIN Ribbon Connectors (2x4Pin Female) + Cables [[https:// | + | 4x 8PIN Ribbon Connectors (2x4Pin Female) + Cables [[https:// |
- | 2x 8PIN Ribbon Terminals (2x4Pin Male) SMD Variant [[https:// | + | 2x 8PIN Ribbon Terminals (2x4Pin Male) SMD Variant [[https:// |
- | 2x 0.96" SSD1306 Screens 7Pin Variant! i recommend white ones [[https:// | + | 2x 0.96" SSD1306 Screens 7Pin Variant! i recommend white ones, order 2 extras because you might have faulty ones because of Heat-Soldering Damage and replacement for later repair.. |
+ | 2x 8Pin Ribbon Cables (i recommend to order a lot off them)\\ | ||
+ | 2x M3 Black Screws - cant remember the length - 1,5cm is enough\\ | ||
+ | 2x M3 Black Acrylic Spacers - cant remember the right length - i guess 6mm? [[https:// | ||
+ | 2x M3 Nuts\\ | ||
Line 39: | Line 48: | ||
I made a DXF File which you can send to [[https:// | I made a DXF File which you can send to [[https:// | ||
- | i panalized it so there are 2 Plates in it\\ | + | i panalized it so there are 2 Plates in it: {{: |
I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ | I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ | ||
+ | i panalized it so there are 2 Plates and 2x Plates for a [[• lre5-lcd2]] in it:{{: | ||
+ | I payed 45€ summed for booth plates incl shipping from Germany to Austria\\ | ||
**Recommend Material from Formulor: | **Recommend Material from Formulor: | ||
3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ | 3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ | ||
====== To Do ====== | ====== To Do ====== |
lre-oled-bar2.txt · Last modified: 2023/09/12 14:24 by phatline
