lre-oled-bar2
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
lre-oled-bar2 [2023/09/07 20:52] – [Building and BOM] phatline | lre-oled-bar2 [2023/09/12 14:24] (current) – [Frontpanel] phatline | ||
Line 12: | Line 12: | ||
Here are the gerberfiles for production - i made it with[[https:// | Here are the gerberfiles for production - i made it with[[https:// | ||
- | {{: | + | These are the settings, if you want to V-Groove it you have to panalize it at 2x4 PCBs at one pcb. |
+ | the minimal order is 5 PCBs... so you may have then 4 sets left that you can sell or make a present for anyone...\\ | ||
+ | If you use EuroPacket as shipping method you will pay 26€ / thats incl import duty and taxes!\\ | ||
====== Hardware Requirements ====== | ====== Hardware Requirements ====== | ||
- | * [[http:// | + | * a[[http:// |
- | * [[DisplayDriver-SMD]] which buffers the Displays | + | * [[DisplayDriver-SMD]] which buffers the Displays, they are already assambled, and 5 pieces costs around 60€ - you only need 1 PCB here (60/ |
* Soldering Iron - with a Dip that can Handle Thruhole-Parts, | * Soldering Iron - with a Dip that can Handle Thruhole-Parts, | ||
* [[mb-lre8x2cs_pcb]] for its nature use\\ | * [[mb-lre8x2cs_pcb]] for its nature use\\ | ||
* [[LRE5-LCD2]] as UI to handle Patch management and automation (if you want to use my code...) | * [[LRE5-LCD2]] as UI to handle Patch management and automation (if you want to use my code...) | ||
* You may need a [[http:// | * You may need a [[http:// | ||
+ | * If you have not already - you will need a IDC-Crimper for all your Midibox Cables [[https:// | ||
====== Shematic ====== | ====== Shematic ====== | ||
Line 44: | Line 48: | ||
I made a DXF File which you can send to [[https:// | I made a DXF File which you can send to [[https:// | ||
- | i panalized it so there are 2 Plates in it\\ | + | 2 Plates in one File: {{: |
I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ | I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ | ||
- | **Recommend Material from Formulor:**\\ | + | 2 Plates & 2 Plates for a [[• lre5-lcd2]] in one File:{{: |
- | 3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ | + | I payed 45€ summed for booth plates incl shipping from Germany to Austria\\ |
+ | **Recommend Material from Formulor: | ||
+ | 3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ | ||
====== To Do ====== | ====== To Do ====== | ||
The LRE-OLED-Bar | The LRE-OLED-Bar |
lre-oled-bar2.txt · Last modified: 2023/09/12 14:24 by phatline
