pedal_box
Differences
pedal_box [2010/04/13 07:50] – durisian | pedal_box [2011/02/17 12:36] – durisian | ||
Line 169: | Line 169: | ||
Line 397: | Line 412: | ||
<box 46% left round bluedark|Device Bankstick Downloads> | <box 46% left round bluedark|Device Bankstick Downloads> | ||
- | [[http:// | + | {{:mcrozier:v-amp.zip|Behringer V-Amp Series}} |
<box 46% left round|PC Editor> | <box 46% left round|PC Editor> | ||
- | [[http:// | + | {{:mcrozier: |
+ | Please note the editor requires a minimum of WinXP with .Net 3.5 \\ | ||
- | + | <box 98% round|Docs> | |
Line 594: | Line 610: | ||
The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\ | The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\ | ||
The second digit (ten' | The second digit (ten' | ||
+ | If only 1 digit is used, and bank goes higher than 9. The dot will light up to let you know that ' | ||
In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. | In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. | ||
Line 622: | Line 640: | ||
==== Connection Overview ==== | ==== Connection Overview ==== | ||
{{http:// | {{http:// | ||
+ | **Please Note:** Default connections have changed since 2.6. The default has only one digit connected to SR 5. With bank and PedalSwap footswitches and LED's attched to SR 4 | ||
Pedal Board Test Bench \\ | Pedal Board Test Bench \\ |
pedal_box.txt · Last modified: 2014/01/19 10:10 by shuriken
