soundcards_with_ymf262_and_or_yac512_chips [2009/03/19 00:33] SuburbanBoy some formatting and translations |
soundcards_with_ymf262_and_or_yac512_chips [2012/11/26 23:57] smashtv old revision restored (spam kill) |
Line 1: | Line 1: | ||
====== Chip Reference Table ====== | ====== Chip Reference Table ====== | ||
- | This page is a listing of PC soundcards which contain or do not contain the two chips ([[YMF262]] & [[YAC512]]) necessary to stuff a [[home#mbhpmidibox_hardware_platform|MBHP]] [[opl3_module|OPL3 Module]] in order to build a [[:home:project:synthesizer:midibox_fm|MIDIBox FM Synthesiser]] | + | This page is a listing of PC soundcards which contain or do not contain the two chips ([[YMF262]] & [[YAC512]]) necessary to stuff a [[home#mbhpmidibox_hardware_platform|MBHP]] [[opl3_module|OPL3 Module]] in order to build a [[:home:project:midibox_fm|MIDIBox FM Synthesiser]] |
** Please add chip name to the first two columns to indicate the presence of that chip. ** | ** Please add chip name to the first two columns to indicate the presence of that chip. ** | ||
Line 10: | Line 10: | ||
|YMF262-M|YAC512-M|Acer|MAGIC S22|94421-1| |FCC ID: IPLMAGIC-S22| | |YMF262-M|YAC512-M|Acer|MAGIC S22|94421-1| |FCC ID: IPLMAGIC-S22| | ||
|YMF262-M|YAC512-M|Acer|MAGIC S22|94421-2| |FCC ID: IPLMAGIC-S22| | |YMF262-M|YAC512-M|Acer|MAGIC S22|94421-2| |FCC ID: IPLMAGIC-S22| | ||
- | |YMF262-M/YMZ263-F|YAC512-M|Ad Lib Inc|AdLib|Gold 1000 Rev-3| | FCC ID: KBWGD1000 | | + | |YMF262-M|YAC512-M|Acer|MAGIC S32/S23|95322-1| |FCC ID: IPLS32-23| |
+ | |YMF262-M|YAC512-M|Analog Devices|Ad1848| Mf-009 | | | | ||
+ | |YMF262-M/YMZ263-F|YAC512-M|Ad Lib Inc.|AdLib|Gold 1000 Rev-3| | FCC ID: KBWGD1000 | | ||
+ | |No|No|Aztech|MM|Pro16V-A| |FCC ID: I38-SN96116| | ||
+ | |YMF262-M|YAC512-M|AZTECH|MM PRO 16IIA-3D FP-6L| | | | | ||
|YMF262-M|YAC512-M|Aztech|SoundGalaxy|Basic 16|138-MMSN830| | | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Basic 16|138-MMSN830| | | ||
- | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16|138-MMSN810|YMF-262 incorporated into ASIC on this card | | + | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16|138-MMSN810|YMF-262 incorporated into ASIC on this card| |
- | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|138-MMSN822|YMF-262 incorporated into ASIC on this card | | + | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|138-MMSN822|YMF-262 incorporated into ASIC on this card| |
+ | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|V1-1 A|FCC ID: I38-MMSN822 (1994)| | ||
+ | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|V5.1|FCC ID: I38-MMSN822| | ||
+ | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Pro 16 II| |FCC ID: I38-MMSN845 (1995)| | ||
+ | |YMF262-M|YAC512-M|Aztech|?| | |FCC ID: 138-MMSN850| | ||
+ | |YMF262-M|?|Aztech|SoundGalaxy|Waverider Pro 32+| |FCC ID: I38-MMSN826| | ||
|YMF262-M|YAC512-M|Aztech|SoundGalaxy|Waverider Pro 32-3D|138-MMSN852| | | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Waverider Pro 32-3D|138-MMSN852| | | ||
|?|?|Creative|SoundBlaster|1.0 / 1.5|CT1320| | | |?|?|Creative|SoundBlaster|1.0 / 1.5|CT1320| | | ||
Line 22: | Line 31: | ||
|YMF262-M|YAC512-M|Creative|SoundBlaster|16 ASP|CT1740| | | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 ASP|CT1740| | | ||
|YMF262-M|YAC512-M|Creative|SoundBlaster|16 MCD ASP|CT1750| | | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 MCD ASP|CT1750| | | ||
- | |?|?|Creative|SoundBlaster|16 SCSI-2 ASP|CT1770| | | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 SCSI-2 ASP|CT1770| | |
|?|?|Creative|SoundBlaster|16 SCSI-2|CT1779| | | |?|?|Creative|SoundBlaster|16 SCSI-2|CT1779| | | ||
- | |?|?|Creative|SoundBlaster|16 MCD ASP|CT2230| | | + | |No|No|Creative|SoundBlaster|16 MCD ASP|CT2230| | |
|?|?|Creative|SoundBlaster|16 ASP|CT2230C| | | |?|?|Creative|SoundBlaster|16 ASP|CT2230C| | | ||
|?|?|Creative|SoundBlaster|16 Sony ASP|CT2230S| | | |?|?|Creative|SoundBlaster|16 Sony ASP|CT2230S| | | ||
Line 30: | Line 39: | ||
|?|?|Creative|SoundBlaster|16|CT2239C| | | |?|?|Creative|SoundBlaster|16|CT2239C| | | ||
|?|?|Creative|SoundBlaster|16 Sony|CT2239S| | | |?|?|Creative|SoundBlaster|16 Sony|CT2239S| | | ||
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 MCD|CT2260|(OEM-Version of the CT2230)| | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 MCD|CT2260|(OEM-Version of the CT2230)| |
|No|No|Creative|SoundBlaster|16 Pro ASP|CT2290| | | |No|No|Creative|SoundBlaster|16 Pro ASP|CT2290| | | ||
|?|?|Creative|SoundBlaster|16 Value IDE|CT2291| | | |?|?|Creative|SoundBlaster|16 Value IDE|CT2291| | | ||
Line 39: | Line 48: | ||
|?|?|Creative|SoundBlaster|Easy 16|CT2750| | | |?|?|Creative|SoundBlaster|Easy 16|CT2750| | | ||
|No|No|Creative|SoundBlaster|16 Value|CT2770| | | |No|No|Creative|SoundBlaster|16 Value|CT2770| | | ||
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 IDE|CT2800|(OEM-Version of the CT2291)| | + | |YMF262-M|YAC512-?|Creative|SoundBlaster|16 IDE|CT2800|(OEM-Version of the CT2291)| |
|YMF262-?|YAC512-?|Creative|SoundBlaster|16 IDE|CT2810|(OEM-Version of the CT2291)| | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 IDE|CT2810|(OEM-Version of the CT2291)| | ||
|?|?|Creative|SoundBlaster|16 IDE ASP|CT2830| | | |?|?|Creative|SoundBlaster|16 IDE ASP|CT2830| | | ||
Line 46: | Line 55: | ||
|YMF262-M|YAC512-M|Creative|SoundBlaster|16|CT2860|(OEM-Version of the CT2291 w/o IDE)| | |YMF262-M|YAC512-M|Creative|SoundBlaster|16|CT2860|(OEM-Version of the CT2291 w/o IDE)| | ||
|YMF262-M|YAC512-M|Creative|SoundBlaster|16 IDE PnP|CT2890|(OEM-Version of the CT2959)| | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 IDE PnP|CT2890|(OEM-Version of the CT2959)| | ||
- | |?|?|Creative|SoundBlaster|16 Pro|CT2910| | | + | |No|No|Creative|SoundBlaster|16 Pro|CT2910| | |
- | |?|?|Creative|SoundBlaster|16 Pro Value|CT2911| | | + | |No|?|Creative|SoundBlaster|16 Pro Value|CT2911| | |
|?|?|Creative|SoundBlaster|16 Pro ASP|CT2919| | | |?|?|Creative|SoundBlaster|16 Pro ASP|CT2919| | | ||
|?|?|Creative|SoundBlaster|16 PnP|CT2929| | | |?|?|Creative|SoundBlaster|16 PnP|CT2929| | | ||
|No|No|Creative|SoundBlaster|16 IDE PnP|CT2940|(OEM-Version of the CT2959)| | |No|No|Creative|SoundBlaster|16 IDE PnP|CT2940|(OEM-Version of the CT2959)| | ||
|No|No|Creative|SoundBlaster|16 PnP|CT2950| | | |No|No|Creative|SoundBlaster|16 PnP|CT2950| | | ||
- | |?|?|Creative|SoundBlaster|16 PnP|CT2959| | | + | |No|No|Creative|SoundBlaster|16 PnP|CT2959| | |
|No|No|Creative|SoundBlaster|16 Vibra PnP|CT2960| | | |No|No|Creative|SoundBlaster|16 Vibra PnP|CT2960| | | ||
|?|?|Creative|SoundBlaster|16 Vibra PnP|CT2961| | | |?|?|Creative|SoundBlaster|16 Vibra PnP|CT2961| | | ||
Line 66: | Line 75: | ||
|No|No|Creative|Soundblaster|AWE32|CT3620| | | |No|No|Creative|Soundblaster|AWE32|CT3620| | | ||
|?|?|Creative|SoundBlaster|AWE32 Value|CT3780| | | |?|?|Creative|SoundBlaster|AWE32 Value|CT3780| | | ||
- | |?|?|Creative|SoundBlaster|AWE32 MKE/IDE|CT3900| | | + | |No|No|Creative|SoundBlaster|AWE32 MKE/IDE|CT3900|The OPL3 Chip is a CT1747| |
|?|?|Creative|SoundBlaster|AWE32 Value IDE|CT3919| | | |?|?|Creative|SoundBlaster|AWE32 Value IDE|CT3919| | | ||
|?|?|Creative|SoundBlaster|AWE32 PnP|CT3960| | | |?|?|Creative|SoundBlaster|AWE32 PnP|CT3960| | | ||
Line 81: | Line 90: | ||
|No|No|Creative|Soundblaster|Vibra|CT4810| | | |No|No|Creative|Soundblaster|Vibra|CT4810| | | ||
|YMF262-M|YAC512-M|Creative|SoundBlaster|16 Vibra| |Laptop MAXDATA FT6000A (onboard)| | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 Vibra| |Laptop MAXDATA FT6000A (onboard)| | ||
+ | |YMF-262-M|YAC512-M|Creative|Phone Blaster|28.8|CT3120|there are versions w/ and w/o the chips| | ||
|YMF262-M|?|Diamond Computer Systems|Sonic Sound|LX OP (?)| |FCC ID: K2Y-AUDIO16C| | |YMF262-M|?|Diamond Computer Systems|Sonic Sound|LX OP (?)| |FCC ID: K2Y-AUDIO16C| | ||
|YMF262-M|YAC512-M|Diamond Computer Systems|Sonic Sound (?)|59-006781F-1002 REV 1.3| |FCC ID: K2Y-PRO16| | |YMF262-M|YAC512-M|Diamond Computer Systems|Sonic Sound (?)|59-006781F-1002 REV 1.3| |FCC ID: K2Y-PRO16| | ||
Line 89: | Line 99: | ||
|YMF262-M|YAC512-M|Media Vision|Jazz 16| | | | |YMF262-M|YAC512-M|Media Vision|Jazz 16| | | | ||
|YMF262-M|YAC512-M|Media Vision|PROAUDIO 3D| |650-0111-51A|FCC ID: IXW-PASUM3D| | |YMF262-M|YAC512-M|Media Vision|PROAUDIO 3D| |650-0111-51A|FCC ID: IXW-PASUM3D| | ||
+ | |No|No|Media Vision|Pro Audio Spectrum| | |FCC ID: IXW650-0002-00(1991)| | ||
|YMF262-M|?|Media Vision|Pro Audio Spectrum|16| |FCC ID: IXW-MVIPA16NS| | |YMF262-M|?|Media Vision|Pro Audio Spectrum|16| |FCC ID: IXW-MVIPA16NS| | ||
|YMF262-M|?|Media Vision|Pro Audio Spectrum|Plus|PCB 600-0014-05 REV. E|FCC ID: IXW-MVIPAS2| | |YMF262-M|?|Media Vision|Pro Audio Spectrum|Plus|PCB 600-0014-05 REV. E|FCC ID: IXW-MVIPAS2| | ||
Line 94: | Line 105: | ||
|YMF262-M|YAC512-M|Oak Technologie|Mozart|BTC1820|REV.A| | | |YMF262-M|YAC512-M|Oak Technologie|Mozart|BTC1820|REV.A| | | ||
|YMF262-M|YAC512-M|OPTi Inc|930 Soundsystem| |S0930S0010|IDE/PAN/SONY/MIT| | |YMF262-M|YAC512-M|OPTi Inc|930 Soundsystem| |S0930S0010|IDE/PAN/SONY/MIT| | ||
+ | |YMF262-M|YAC512-M|Packard Bell|030069| | |Rebadged version of another card?| | ||
+ | |No|No|Pearl|Hypersound|16|REV 1.1|FCC ID: KWX-SC1630| | ||
|YMF262-M|YAC512-M|Phillips|PCA70PS| | | | | |YMF262-M|YAC512-M|Phillips|PCA70PS| | | | | ||
|YMF262-M|YAC512-M|QuickShot|QS-838|REV 1.6| | | | |YMF262-M|YAC512-M|QuickShot|QS-838|REV 1.6| | | |
