soundcards_with_ymf262_and_or_yac512_chips [2007/07/15 18:05] housemaster |
soundcards_with_ymf262_and_or_yac512_chips [2012/11/26 23:57] (current) smashtv old revision restored (spam kill) |
Line 1: | Line 1: | ||
====== Chip Reference Table ====== | ====== Chip Reference Table ====== | ||
- | This page is a listing of PC soundcards which contain or do not contain the [[YMF262|two]] [[YAC512|chips]] necessary to stuff a [[home#mbhpmidibox_hardware_platform|MBHP]] [[opl3_module|OPL3 Module]] in order to build a [[midibox_fm|MIDIBox FM Synthesiser]] | + | This page is a listing of PC soundcards which contain or do not contain the two chips ([[YMF262]] & [[YAC512]]) necessary to stuff a [[home#mbhpmidibox_hardware_platform|MBHP]] [[opl3_module|OPL3 Module]] in order to build a [[:home:project:midibox_fm|MIDIBox FM Synthesiser]] |
+ | ** Please add chip name to the first two columns to indicate the presence of that chip. ** | ||
- | == Please add chip name to the first two columns to indicate the presence of that chip. == | ||
//Please try to keep entries in alphabetical order for clarity// | //Please try to keep entries in alphabetical order for clarity// | ||
^YMF262?^YAC512?^Brand^Model Name^Model Number^Part Number^Comments^ | ^YMF262?^YAC512?^Brand^Model Name^Model Number^Part Number^Comments^ | ||
- | |YMF262-M/YMZ263-F|YAC512-M|Ad Lib Inc|AdLib|Gold 1000 Rev-3| | FCC ID: KBWGD1000 | | + | |YMF262-M|YAC512-M|Acer|MAGIC S22|94421-1| |FCC ID: IPLMAGIC-S22| |
+ | |YMF262-M|YAC512-M|Acer|MAGIC S22|94421-2| |FCC ID: IPLMAGIC-S22| | ||
+ | |YMF262-M|YAC512-M|Acer|MAGIC S32/S23|95322-1| |FCC ID: IPLS32-23| | ||
+ | |YMF262-M|YAC512-M|Analog Devices|Ad1848| Mf-009 | | | | ||
+ | |YMF262-M/YMZ263-F|YAC512-M|Ad Lib Inc.|AdLib|Gold 1000 Rev-3| | FCC ID: KBWGD1000 | | ||
+ | |No|No|Aztech|MM|Pro16V-A| |FCC ID: I38-SN96116| | ||
+ | |YMF262-M|YAC512-M|AZTECH|MM PRO 16IIA-3D FP-6L| | | | | ||
|YMF262-M|YAC512-M|Aztech|SoundGalaxy|Basic 16|138-MMSN830| | | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Basic 16|138-MMSN830| | | ||
- | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16|138-MMSN810|YMF-262 incorporated into ASIC on this card | | + | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16|138-MMSN810|YMF-262 incorporated into ASIC on this card| |
- | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|138-MMSN822|YMF-262 incorporated into ASIC on this card | | + | |No|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|138-MMSN822|YMF-262 incorporated into ASIC on this card| |
+ | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|V1-1 A|FCC ID: I38-MMSN822 (1994)| | ||
+ | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Pro 16 II|V5.1|FCC ID: I38-MMSN822| | ||
+ | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Pro 16 II| |FCC ID: I38-MMSN845 (1995)| | ||
+ | |YMF262-M|YAC512-M|Aztech|?| | |FCC ID: 138-MMSN850| | ||
+ | |YMF262-M|?|Aztech|SoundGalaxy|Waverider Pro 32+| |FCC ID: I38-MMSN826| | ||
|YMF262-M|YAC512-M|Aztech|SoundGalaxy|Waverider Pro 32-3D|138-MMSN852| | | |YMF262-M|YAC512-M|Aztech|SoundGalaxy|Waverider Pro 32-3D|138-MMSN852| | | ||
- | |No|No|ESS|AudioDrive|FM16PNP| | | | ||
|?|?|Creative|SoundBlaster|1.0 / 1.5|CT1320| | | |?|?|Creative|SoundBlaster|1.0 / 1.5|CT1320| | | ||
|No|No|Creative|SoundBlaster|2|CT1350B| | | |No|No|Creative|SoundBlaster|2|CT1350B| | | ||
Line 18: | Line 29: | ||
|YMF262-M|YAC512-M|Creative|SoundBlaster|Pro 2|CT1600| |FCC ID: IBACT-SBP2P5 | |YMF262-M|YAC512-M|Creative|SoundBlaster|Pro 2|CT1600| |FCC ID: IBACT-SBP2P5 | ||
|?|?|Creative|SoundBlaster|16|CT1730| | | |?|?|Creative|SoundBlaster|16|CT1730| | | ||
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 ASP|CT1740| | | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 ASP|CT1740| | |
|YMF262-M|YAC512-M|Creative|SoundBlaster|16 MCD ASP|CT1750| | | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 MCD ASP|CT1750| | | ||
- | |?|?|Creative|SoundBlaster|16 SCSI\-2 ASP|CT1770| | | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 SCSI-2 ASP|CT1770| | |
- | |?|?|Creative|SoundBlaster|16 SCSI\-2|CT1779| | | + | |?|?|Creative|SoundBlaster|16 SCSI-2|CT1779| | |
- | |?|?|Creative|SoundBlaster|16 MCD ASP|CT2230| | | + | |No|No|Creative|SoundBlaster|16 MCD ASP|CT2230| | |
|?|?|Creative|SoundBlaster|16 ASP|CT2230C| | | |?|?|Creative|SoundBlaster|16 ASP|CT2230C| | | ||
|?|?|Creative|SoundBlaster|16 Sony ASP|CT2230S| | | |?|?|Creative|SoundBlaster|16 Sony ASP|CT2230S| | | ||
Line 28: | Line 39: | ||
|?|?|Creative|SoundBlaster|16|CT2239C| | | |?|?|Creative|SoundBlaster|16|CT2239C| | | ||
|?|?|Creative|SoundBlaster|16 Sony|CT2239S| | | |?|?|Creative|SoundBlaster|16 Sony|CT2239S| | | ||
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 MCD|CT2260|(OEM\-Version der CT2230)| | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 MCD|CT2260|(OEM-Version of the CT2230)| |
|No|No|Creative|SoundBlaster|16 Pro ASP|CT2290| | | |No|No|Creative|SoundBlaster|16 Pro ASP|CT2290| | | ||
|?|?|Creative|SoundBlaster|16 Value IDE|CT2291| | | |?|?|Creative|SoundBlaster|16 Value IDE|CT2291| | | ||
Line 37: | Line 48: | ||
|?|?|Creative|SoundBlaster|Easy 16|CT2750| | | |?|?|Creative|SoundBlaster|Easy 16|CT2750| | | ||
|No|No|Creative|SoundBlaster|16 Value|CT2770| | | |No|No|Creative|SoundBlaster|16 Value|CT2770| | | ||
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 IDE|CT2800|(OEM\-Version der CT2291)| | + | |YMF262-M|YAC512-?|Creative|SoundBlaster|16 IDE|CT2800|(OEM-Version of the CT2291)| |
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 IDE|CT2810|(OEM\-Version der CT2291)| | + | |YMF262-?|YAC512-?|Creative|SoundBlaster|16 IDE|CT2810|(OEM-Version of the CT2291)| |
|?|?|Creative|SoundBlaster|16 IDE ASP|CT2830| | | |?|?|Creative|SoundBlaster|16 IDE ASP|CT2830| | | ||
- | |?|?|Creative|SoundBlaster|16 IDE|CT2840|(OEM\-Version der CT2291)| | + | |?|?|Creative|SoundBlaster|16 IDE|CT2840|(OEM-Version of the CT2291)| |
|?|?|Creative|SoundBlaster|16 IDE|CT2839| | | |?|?|Creative|SoundBlaster|16 IDE|CT2839| | | ||
- | |YMF262-?|YAC512-?|Creative|SoundBlaster|16|CT2860|(OEM\-Version der CT2291 ohne IDE)| | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16|CT2860|(OEM-Version of the CT2291 w/o IDE)| |
- | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 IDE PnP|CT2890|(OEM\-Version der CT2959)| | + | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 IDE PnP|CT2890|(OEM-Version of the CT2959)| |
- | |?|?|Creative|SoundBlaster|16 Pro|CT2910| | | + | |No|No|Creative|SoundBlaster|16 Pro|CT2910| | |
- | |?|?|Creative|SoundBlaster|16 Pro Value|CT2911| | | + | |No|?|Creative|SoundBlaster|16 Pro Value|CT2911| | |
|?|?|Creative|SoundBlaster|16 Pro ASP|CT2919| | | |?|?|Creative|SoundBlaster|16 Pro ASP|CT2919| | | ||
|?|?|Creative|SoundBlaster|16 PnP|CT2929| | | |?|?|Creative|SoundBlaster|16 PnP|CT2929| | | ||
- | |No|No|Creative|SoundBlaster|16 IDE PnP|CT2940|(OEM\-Version der CT2959)| | + | |No|No|Creative|SoundBlaster|16 IDE PnP|CT2940|(OEM-Version of the CT2959)| |
|No|No|Creative|SoundBlaster|16 PnP|CT2950| | | |No|No|Creative|SoundBlaster|16 PnP|CT2950| | | ||
- | |?|?|Creative|SoundBlaster|16 PnP|CT2959| | | + | |No|No|Creative|SoundBlaster|16 PnP|CT2959| | |
|No|No|Creative|SoundBlaster|16 Vibra PnP|CT2960| | | |No|No|Creative|SoundBlaster|16 Vibra PnP|CT2960| | | ||
|?|?|Creative|SoundBlaster|16 Vibra PnP|CT2961| | | |?|?|Creative|SoundBlaster|16 Vibra PnP|CT2961| | | ||
Line 56: | Line 67: | ||
|?|?|Creative|SoundBlaster|32|CT3930| | | |?|?|Creative|SoundBlaster|32|CT3930| | | ||
|No|No|Creative|SoundBlaster|32 IDE PnP|CT3600| | | |No|No|Creative|SoundBlaster|32 IDE PnP|CT3600| | | ||
- | |?|?|Creative|SoundBlaster|32 PnP|CT3604|(OEM\-Version der CT3620 ohne IDE)| | + | |?|?|Creative|SoundBlaster|32 PnP|CT3604|(OEM-Version of the CT3620 w/o IDE)| |
|?|?|Creative|SoundBlaster|32 IDE PnP|CT3620| | | |?|?|Creative|SoundBlaster|32 IDE PnP|CT3620| | | ||
|?|?|Creative|SoundBlaster|32 IDE PnP|CT3671| | | |?|?|Creative|SoundBlaster|32 IDE PnP|CT3671| | | ||
|?|?|Creative|SoundBlaster|AWE32|CT2760| | | |?|?|Creative|SoundBlaster|AWE32|CT2760| | | ||
|?|?|Creative|SoundBlaster|AWE32|CT2760|Rev.3| | |?|?|Creative|SoundBlaster|AWE32|CT2760|Rev.3| | ||
- | |?|?|Creative|SoundBlaster|AWE32 PnP|CT3601|(OEM\-Version der CT3960 ohne IDE)| | + | |?|?|Creative|SoundBlaster|AWE32 PnP|CT3601|(OEM-Version of the CT3960 w/o IDE)| |
|No|No|Creative|Soundblaster|AWE32|CT3620| | | |No|No|Creative|Soundblaster|AWE32|CT3620| | | ||
|?|?|Creative|SoundBlaster|AWE32 Value|CT3780| | | |?|?|Creative|SoundBlaster|AWE32 Value|CT3780| | | ||
- | |?|?|Creative|SoundBlaster|AWE32 MKE/IDE|CT3900| | | + | |No|No|Creative|SoundBlaster|AWE32 MKE/IDE|CT3900|The OPL3 Chip is a CT1747| |
|?|?|Creative|SoundBlaster|AWE32 Value IDE|CT3919| | | |?|?|Creative|SoundBlaster|AWE32 Value IDE|CT3919| | | ||
|?|?|Creative|SoundBlaster|AWE32 PnP|CT3960| | | |?|?|Creative|SoundBlaster|AWE32 PnP|CT3960| | | ||
Line 74: | Line 85: | ||
|?|?|Creative|SoundBlaster|AWE64 PnP|CT4381| | | |?|?|Creative|SoundBlaster|AWE64 PnP|CT4381| | | ||
|?|?|Creative|SoundBlaster|AWE64 Gold|CT4390| | | |?|?|Creative|SoundBlaster|AWE64 Gold|CT4390| | | ||
- | |?|?|Creative|SoundBlaster|AWE64 Value|CT4500| | | + | |No|No|Creative|SoundBlaster|AWE64 Value|CT4500| | |
|No|No|Creative|SoundBlaster|AWE64 Value|CT4520| | | |No|No|Creative|SoundBlaster|AWE64 Value|CT4520| | | ||
- | |YMF262-M|YAC512-M|Media Vision|PROAUDIO 3D| |650-0111-51A|FCC ID: IXW-PASUM3D| | + | |No|No|Creative|SoundBlaster|Live!|CT4670| | |
+ | |No|No|Creative|Soundblaster|Vibra|CT4810| | | ||
+ | |YMF262-M|YAC512-M|Creative|SoundBlaster|16 Vibra| |Laptop MAXDATA FT6000A (onboard)| | ||
+ | |YMF-262-M|YAC512-M|Creative|Phone Blaster|28.8|CT3120|there are versions w/ and w/o the chips| | ||
+ | |YMF262-M|?|Diamond Computer Systems|Sonic Sound|LX OP (?)| |FCC ID: K2Y-AUDIO16C| | ||
+ | |YMF262-M|YAC512-M|Diamond Computer Systems|Sonic Sound (?)|59-006781F-1002 REV 1.3| |FCC ID: K2Y-PRO16| | ||
+ | |No|No|ESS|AudioDrive|FM16PNP| | | | ||
+ | |YMF262-M|YAC512-M|Logitech|SoundMan Games| |Rev. C|FCC ID: DZLSNDMNGM| | ||
+ | |YMF262-M|?|I/O Magic|Magic Sound 16| | |FCC ID: DXLSK803| | ||
+ | |YMF262-M|YAC512-M|Media Magic (?)|AUDIO 16C| | |FCC ID: K2Y-AUDIO16C| | ||
+ | |YMF262-M|YAC512-M|Media Vision|Jazz 16| | | | ||
+ | |YMF262-M|YAC512-M|Media Vision|PROAUDIO 3D| |650-0111-51A|FCC ID: IXW-PASUM3D| | ||
+ | |No|No|Media Vision|Pro Audio Spectrum| | |FCC ID: IXW650-0002-00(1991)| | ||
+ | |YMF262-M|?|Media Vision|Pro Audio Spectrum|16| |FCC ID: IXW-MVIPA16NS| | ||
+ | |YMF262-M|?|Media Vision|Pro Audio Spectrum|Plus|PCB 600-0014-05 REV. E|FCC ID: IXW-MVIPAS2| | ||
|YMF262-M|YAC512-M|Microsoft Corp|Windows SOUNDSYSTEM| |900-310-011-B|FCC ID: C3KYFMA| | |YMF262-M|YAC512-M|Microsoft Corp|Windows SOUNDSYSTEM| |900-310-011-B|FCC ID: C3KYFMA| | ||
+ | |YMF262-M|YAC512-M|Oak Technologie|Mozart|BTC1820|REV.A| | | ||
|YMF262-M|YAC512-M|OPTi Inc|930 Soundsystem| |S0930S0010|IDE/PAN/SONY/MIT| | |YMF262-M|YAC512-M|OPTi Inc|930 Soundsystem| |S0930S0010|IDE/PAN/SONY/MIT| | ||
+ | |YMF262-M|YAC512-M|Packard Bell|030069| | |Rebadged version of another card?| | ||
+ | |No|No|Pearl|Hypersound|16|REV 1.1|FCC ID: KWX-SC1630| | ||
+ | |YMF262-M|YAC512-M|Phillips|PCA70PS| | | | | ||
+ | |YMF262-M|YAC512-M|QuickShot|QS-838|REV 1.6| | | | ||
+ | |?|?|Reveal Computer Products Inc.|Sound FX|SC500 Wave|21-008-014 REV.A|FCC ID: DXL9IL783W| | ||
|YMF262-M|YAC512-M|TeleVideo|teleWave|Q32/SRS|ASSY 143553-60 (REVC) |FCC ID DFCTELWVQ32SRS| | |YMF262-M|YAC512-M|TeleVideo|teleWave|Q32/SRS|ASSY 143553-60 (REVC) |FCC ID DFCTELWVQ32SRS| | ||
+ | |YMF262-M|YAC512-M|Toptek|Golden Sound Card|Pro16ES V1.0| |FCC ID: J5PPRO16ES| | ||
|YMF262-M|YAC512-M|Turtle Beach Systems|monte carlo|P/N 500.2|PCBISP16&2#31|FCC ID K33IFISP16R20| | |YMF262-M|YAC512-M|Turtle Beach Systems|monte carlo|P/N 500.2|PCBISP16&2#31|FCC ID K33IFISP16R20| | ||
+ | === Legend === | ||
+ | |ASP|Advanced Signal Processor| | ||
+ | |MCD|MultiCD for Non-ATAPI-CDROMs| | ||
+ | |SCSI-2|SCSI-2 Interface| | ||
+ | |Sony|for SONY Non-ATAPI-CDROMs| | ||
+ | |Pro|44.1 kHz Recording devices| | ||
+ | |Value|"reasonable" reduced| | ||
+ | |PnP|Plug'n'Play| | ||
+ | |Easy|???| | ||
+ | |MKE|MITSUMI Non-ATAPI-CDROM-PORT| | ||
+ | |Vibra|SB16, but with SBPro-Mixerchip| | ||
+ | ====== Useful resources ====== | ||
- | **Legend** | + | http://museum.gravisultrasound.net/ is a czech soundcard gallery with a lot of big sized photos. |
- | ASP=Advanced Signal Processor\\ | + | |
- | MCD=MultiCD für Nicht\-ATAPI\-CDROMs\\ | + | |
- | SCSI\-2=SCSI\-2 Schnittstelle\\ | + | |
- | Sony=für SONY Nicht\-ATAPI\-CDROMs\\ | + | |
- | Pro=44.1 kHz Aufnahmerate\\ | + | |
- | Value="sinnvoll" abgespeckt\\ | + | |
- | PnP=Plug und Play\\ | + | |
- | Easy=???\\ | + | |
- | MKE=MITSUMI Nicht\-ATAPI\-CDROM\-PORT\\ | + | |
- | Vibra=SB16, aber mit SBPro\-Mixerchip\\ | + |
