acsim_mios_h
This page is part of the mios_c_simulator_-_debugger
ACSim_console.h
ACSim_console.c
ACSim_toolbox.h
ACSim_toolbox.c
ACMidiDefines.h
This code is for viewing only and may not be up to date. You can download the files in a .zip file here. If you make any updates, please send them to stryd_one and he will update the zip for you.
/* * ACSim_mios.h * v 0.0.7 * * 2006 April 06 Created by Michael Markert, http://www.audiocommander.de * mios simulator header for MIOS (c) by T. Klose, http://www.midibox.org * */ /* * Released under GNU General Public License * http://www.gnu.org/licenses/gpl.html * * This program is free software; you can redistribute it and/or modify it under the terms * of the GNU General Public License as published by the Free Software Foundation * * YOU ARE ALLOWED TO COPY AND CHANGE * BUT YOU MUST RELEASE THE SOURCE TOO (UNDER GNU GPL) IF YOU RELEASE YOUR PRODUCT * YOU ARE NOT ALLOWED TO USE IT WITHIN PROPRIETARY CLOSED-SOURCE PROJECTS */ #ifndef _ACSIM_MIOS_H #define _ACSIM_MIOS_H #import <Stdio.h> #import "ACSim_console.h" #define __wparam #define code const // MIOS definitions #define MIOS_MIDI_INTERFACE_COMMON 0x00 #define MIOS_MIDI_INTERFACE_TO_HOST 0x01 #define MIOS_MIDI_MERGER_DISABLED 0x00 #define MIOS_MIDI_MERGER_ENABLED 0x01 #define MIOS_MIDI_MERGER_MBLINK_EP 0x02 #define MIOS_MIDI_MERGER_MBLINK_FP 0x03 #define MIOS_ENC_SPEED_SLOW 0x00 #define MIOS_ENC_SPEED_NORMAL 0x01 #define MIOS_ENC_SPEED_FAST 0x02 #define MIOS_LCD_TYPE_CLCD 0x00 #define MIOS_LCD_TYPE_GLCD0 0x01 #define MIOS_LCD_TYPE_GLCD1 0x02 #define MIOS_LCD_TYPE_GLCD2 0x03 #define MIOS_LCD_TYPE_GLCD3 0x04 #define MIOS_LCD_TYPE_GLCD4 0x05 #define MIOS_LCD_TYPE_MLCD 0x06 #define MIOS_LCD_TYPE_GLCD_CUSTOM 0x07 #define MIOS_GLCD_FONT 0x28fc // structures of the CFG and STAT bytes typedef union { struct { unsigned ALL:8; }; struct { unsigned LCD_TYPE:3; // selects LCD type unsigned USE_GLCD:1; // if 1, graphical LCD is connected unsigned MERGER:1; // if 1, MIDI merger is enabled unsigned MBLINK:1; // if 1, MIDIbox Link is enabled unsigned TO_HOST:1; // if 1, MIDI interface will run with 38400 baud instead of 31250 unsigned FRQ_20MHz:1; // if 1, it is assumed that the bux is running with 20 MHz, else with 40 MHz }; } mios_box_cfg0_t; typedef union { struct { unsigned ALL:8; }; struct { unsigned BS_A:3; // A2..A0 of BankStick unsigned BS_DIS_VERIFY:1; // if 1, writes to the BankStick will not be verified unsigned IIC_STRETCH_CLK:1; // if 1, IIC clock stretching enabled unsigned :1; unsigned :1; unsigned :1; }; } mios_box_cfg1_t; typedef union { struct { unsigned ALL:8; }; struct { unsigned BS_AVAILABLE:1; // if 1, BankStick is available unsigned MBLINK_TUNNEL_PASS:1; // if 1, a MBLinked event will be tunnled unsigned SUSPEND_ALL:1; // if 1, all system and user tasks are suspended unsigned SUSPEND_USER:1; // if 1, all user tasks are suspended unsigned AUTOREPEAT:1; // if 1, start the auto-repeat handler unsigned MLCD_TRANSFER:1; // if 1, a transfer to the MLCD has been started unsigned :1; unsigned :1; }; } mios_box_stat_t; // debug related structures typedef union { struct { unsigned ALL:8; }; struct { unsigned TIMER_ENABLED:1; unsigned free:7; }; } debug_user_timer_t; // mios tables extern const unsigned char MIOS_MPROC_EVENT_TABLE[2*128]; extern const unsigned char MIOS_ENC_PIN_TABLE[2*64]; #pragma mark pic18f typedefs // "pic18f452.h" typedefs typedef union { struct { unsigned RC0:1; unsigned RC1:1; unsigned RC2:1; unsigned RC3:1; unsigned RC4:1; unsigned RC5:1; unsigned RC6:1; unsigned RC7:1; }; struct { unsigned T1OSO:1; unsigned T1OSI:1; unsigned :1; unsigned SCK:1; unsigned SDI:1; unsigned SDO:1; unsigned TX:1; unsigned RX:1; }; struct { unsigned T1CKI:1; unsigned CCP2:1; unsigned CCP1:1; unsigned SCL:1; unsigned SDA:1; unsigned :1; unsigned CK:1; unsigned DT:1; }; } __PORTCbits_t; typedef union { struct { unsigned RD0:1; unsigned RD1:1; unsigned RD2:1; unsigned RD3:1; unsigned RD4:1; unsigned RD5:1; unsigned RD6:1; unsigned RD7:1; }; struct { unsigned AD0:1; unsigned AD1:1; unsigned AD2:1; unsigned AD3:1; unsigned AD4:1; unsigned AD5:1; unsigned AD6:1; unsigned AD7:1; }; } __PORTDbits_t; typedef union { struct { unsigned RBIF:1; unsigned INT0F:1; unsigned T0IF:1; unsigned RBIE:1; unsigned INT0E:1; unsigned T0IE:1; unsigned PEIE:1; unsigned GIE:1; }; } __INTCONbits_t; #pragma mark debug typedefs // bankstick typedef struct { unsigned char buffer[DEBUG_BANKSTICK_SIZE]; } debug_bankstick_t; #pragma mark mios globals // mios globals extern mios_box_stat_t MIOS_BOX_STAT; // "pic18f452.h" extern __PORTCbits_t PORTCbits; extern __PORTDbits_t PORTDbits; extern __INTCONbits_t INTCONbits; // HLP extern unsigned char MIOS_PARAMETER1; extern unsigned char MIOS_PARAMETER2; extern unsigned char MIOS_PARAMETER3; #pragma mark debug globals // export globals extern debug_user_timer_t debug_user_timer; extern unsigned char debug_ain_lastPin; extern unsigned int debug_ain_value[32]; extern unsigned char debug_din_lastPin; extern unsigned char debug_din_value[32]; extern unsigned int debug_enc_value[32]; extern unsigned char debug_bankstick_ctrl; extern debug_bankstick_t debug_bankstick[DEBUG_BANKSTICK_NUM]; extern unsigned int debug_MIDI_byteNum; extern unsigned int debug_IIC_byteNum; #endif /* _ACSIM_MIOS_H */
acsim_mios_h.1191673140.txt.gz · Last modified: 2007/11/17 16:47 (external edit)
