acsim_toolbox_h
This page is part of the mios_c_simulator_-_debugger
ACSim_console.h
ACSim_console.c
ACSim_toolbox.h
ACSim_toolbox.c
ACMidiDefines.h
This code is for viewing only and may not be up to date. You can download the files in a zip file acsim.zip. If you make any updates, please send them to stryd_one and he will update the zip for you.
/* * ACSim_toolbox.h * v 0.0.5 * * 2006 April 17 Created by Michael Markert, audiocommander.de * Copyright 2006 Michael Markert, http://www.audiocommander.de * hexview based on publicdomain code: http://www.eggdrop.ch/texts/cschnipsel/ * toolbox for mios: http://www.midibox.org * */ /* * Released under GNU General Public License * http://www.gnu.org/licenses/gpl.html * * This program is free software; you can redistribute it and/or modify it under the terms * of the GNU General Public License as published by the Free Software Foundation * * YOU ARE ALLOWED TO COPY AND CHANGE * BUT YOU MUST RELEASE THE SOURCE TOO (UNDER GNU GPL) IF YOU RELEASE YOUR PRODUCT * YOU ARE NOT ALLOWED NOT USE IT WITHIN PROPRIETARY CLOSED-SOURCE PROJECTS */ #import <Stdio.h> #ifndef _ACSIM_TOOLBOX_H #define _ACSIM_TOOLBOX_H // generate some random numbers extern unsigned char ACRandomBool(void); extern signed char ACRandomEncoder(void); extern unsigned char ACRandomPin(void); extern unsigned char ACRandomChar(void); extern unsigned int ACRandomInt(void); // hexview output #define HEXVIEW_COLUMNS 68 #define HEXVIEW_CHARS ((HEXVIEW_COLUMNS-1)/4) extern void hexview(unsigned char *buf, int size); #endif /* _ACSIM_TOOLBOX_H */
acsim_toolbox_h.txt · Last modified: 2007/11/17 16:49 by smashtv
