assembly_language_or_assembler
The opposite of stable; it is unstable. Usually it is used in electronics to describe a particular circuit or part of a circuit. In an astable circuit, the output continually switches between the high and low states without any intervention from the user, producing a square wave. An astable has no stable state; hence the name astable.
assembly_language_or_assembler.1160904901.txt.gz · Last modified: 2007/11/17 18:02 (external edit)
