bandmaster
BANDMASTER
MIDI Routing System and Control Surface.
Scalable MIDI Routing application using the MCAN and the M16 Interface…
Bandmaster CS
The Remote Control.
Top
Bottom
BOM
version 1. Mouser BOM:toDo
Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | Other | Notes |
Resistors | ||||||||
4 | 22R 5% | 0603 | R1, R2, R3, R4 | |||||
1 | 680R 5% | 0603 | R5 | Depends on Led | ||||
PTC fuses, resettable thermistors | ||||||||
1 | 1206L150THWR | 1206 | F1 | 576-1206L150THWR | ||||
Capacitors | ||||||||
1 | 100n | 0603 | C2 | |||||
1 | 4,7u | SMC_A | C1 | |||||
ESD Suppressors / TVS Diodes | ||||||||
7 | CG0603MLC-05E | 0603 | Z1, Z2, Z3, Z4, Z5, Z6, Z7 | 652-CG0603MLC-05E | ||||
Ferrite Bead | ||||||||
1 | BLM21 | 0805 | L1 | 81-BLM21P331SG | ||||
LEDs | ||||||||
1 | – | 0805 or THT | LED_OC | 2x5mm rectangular THT | ||||
Transistor | ||||||||
1 | FDN304P | SSOT-3 | Q1 | 512-FDN304P | P-Channel MOSFET | |||
IC | ||||||||
1 | STMPS2161STR | SOT23-5L | IC1 | 511-STMPS2161STR | Power Switch IC | |||
Connectors | ||||||||
1 | mini-USB | THT | MINI-USB | 571-1734510-1 | ||||
1 | USB-B | THT | USB-B | 538-67068-8000 | ||||
1 | USB-A | THT | MINI-A | 538-48204-0001 | ||||
1 | micro-match 2×4 | Female | J2A | 571-7-215079-8 or 571-2178710-8 (value line) | ||||
1 | micro-match 2×6 | Female | J1A | 571-8-215079-2 or 571-1-2178710-2 (value line) | ||||
Others | ||||||||
2 | Screw terminal | – | – | 534-7790 |
toDo
bandmaster.1538823774.txt.gz · Last modified: 2018/10/06 11:02 by antichambre
