case_and_frontpanels_diy_common_tools
Case / FrontPanel DIY Tools
TODO : Add Pictures
Measurement
  • Flexible Steel Ruler with Cork backing - From Arts stores. An excellent idea that I stole ;)
  • Calipers - For measuring drill bits, shaft diameters, and hole diameters
  • Clamps/Vices - Various sizes and shapes, for holding things still while you drill/saw/bust them up
Drilling
  • Rotary Tool
  • Drill Press - For accurate drilling of PCB's and faceplates
  • Drill bit set
  • Router bit set
  • Nibbling tool - for making odd shaped holes (Careful! These can be savage)
  • Reamer - for making odd shaped holes
  • Center punch - For marking the location of holes to be drilled and scribing lines on metal
Abrasive/Cutting
  • File Set - Flat, round, half round, rasp and needle
  • Hacksaw - For cutting solid objects
  • Spare Hacksaw Blades - For use by hand
  • Coping Saw - For cutting holes in cases
  • Razor Knife - Stanley/X-Acto, etc. NOT for use on plastic cases unless you have a death wish
case_and_frontpanels_diy_common_tools.1465250255.txt.gz · Last modified: 2016/06/06 21:57 by psykhaze
