CC-Looper
Features
* 4Midichannels @ each 512Steps X 32th-looprate X 128 CCs
* only a few of the 128CC should be used @ once - 4x128xCCs @ 32th is Midi Data MESS and µC Death
* maybe only 256Steps, will depend on RAM…. RealWorld will tell
* each TRACK has a shared Track length for all its 128 CCs
* Copy, Paste, Clear: for the all 128CCs/or single CC
* There is no EDIT, you can clear a CC or Track and make a new Take
Hardware Requirements
- You need a Synth with LEDRINGs - otherwise you have no Feedback and Overview - NordRack III is such one
- Melody/Clock Source with ProgramChange-Output: midibox_seq_v4l oops that dont do PC…
- Melody/Clock/CC Destination: NordRack III or any other Synth with Visual Feedback off CC-States
Midibox:
- dipcoref4 - this is the µC Brain for the Looper
- cc-looper - this is the UI-PCB of the Looper
- no other PCBs needet
- µSD-Card, formated with FAT32
- Soldering Iron - with a Dip that can Handle SMD-Parts, Wires, solder Paste for the µC….
- USB Power Supply with µUSB-Connector
Set
Cabeling
Midi IN1 »> MelodySequencer and Remote Devices
Midi IN2 »> Midi Out from Synthesizer - which sends out the Moved CCs
Midi OUT »> Midi IN of Synthesizer input (Automated CCs merged with mididata from Midi IN1)
Software
Firmware
Firmware not made yet
Building
Frontpanel
- a clear Acrylic Frontplate, with NO Engravings, UI-Labeling is viewable from PCB
Case
BOM
Ref | Qty | Value | Footprint | MouserPart | |
C1 – C7 | 7 | 100nF | 0603 Capacitor | 81-GRM33C71C104ME14D | Mouser |
Rec–1 – Rec—4, UI–5 UI—4, led1, -1 -2 -3 -4 | 11 | REC, LED, beat, CC-IN, | 0603 LED | 630-ASMT-RR45-AQ902 | Mouser |
1-16 (LED-BAR) | 64 | bar | 0603 LED | 755-SMLEN3WBC8W1 | Mouser |
D64 D65 | 2 | 1N-4148 | 1206 Diode | 833-1N4148W-TP | Mouser |
PTC1 | 1 | Thermistor_PTC | 1206 Resistor | 576-1206L150THWR | Mouser |
R1, R2, R19 – R34 | 18 | 10K | 1206 Resistor | 603-AC0603FR-0710KL | Mouser |
R3 R5 R6 R7 R8 | 5 | 47 | 1206 Resistor | 603-RC0603FR-0747RL | Mouser |
R9-R14, R36, R37 | 8 | 220 | 1206 Resistor | 603-RC0603FR-07220RL | Mouser |
R15 R16 | 2 | 1K | 1206 Resistor | 603-RC0603JR-071KL | Mouser |
R17 R18 | 2 | 4K7 | 1206 Resistor | 603-RC0603FR-074K7L | Mouser |
OUT1 | 1 | Midi | DIN-8-SDF-80J | 490-SDF-80J | Mouser |
M1 | 1 | DIPCORE32_CMPNT_48P | 517-929870-01-20-RA | DIP-40 | Mouser |
S8 | 1 | Shift | DT6 | 611-D6R00F1LFS | Mouser |
S1 – S4 | 1 | Part1 | 611-SERWHAUOA | DTL2-1-LED | Mouser |
S5 – S7, S9 – S10 | 6 | X,C,V,Len,Pre,Tac | 611-SERRDAUOA | DTL2-1-NO-LED | Mouser |
ENC1 | 1 | ENC_BOURNS_PEC11 | ENC_BOURNS_PEC11+SW | 652-PEC11R-4215F-S24 | Mouser |
IN1 IN2 | 2 | Midi | Midi-Socket-MAB5SH-DIN-5 | 566-MAB5SH | Mouser |
Foot1 | 1 | Pin | |||
J2 | 1 | BootLoad | |||
AIN1 | 1 | PIN | |||
U1 U2 | 2 | 6N136 | SMDIP-8_W11.48mm | 782-6N136-X009 | Mouser |
-595 | 3 | 74HC595 | SO-16-N | 621-74AHC595S16-13 | Mouser |
U3 U4 | 2 | 74LS165 | SO-16-N | 595-SN74LS165ADR | Mouser |
M2 | 1 | µSD_DM3ATDM3AT | ΜSD_DM3AT | 798-DM3AT-SF-PEJM5 | Mouser |
To Do
a housing/case or frontplate
Resources
Community users working on it
I have 10 ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage
