compiling_the_midibox_source_on_linux
Compiling MIOS on Linux
If you ever tried to compile the MIOS source with gpasm on Linux, you've probably got a lot of errormessages like:
svens@deprecated(1033)[0]:./src2$ gpasm main.asm mios_isr.inc:76:Error [103] syntax error mios_isr.inc:77:Error [103] syntax error mios_isr.inc:78:Error [103] syntax error mios_isr.inc:80:Error [103] syntax error mios_isr.inc:81:Error [103] syntax error mios_isr.inc:84:Error [103] syntax error mios_isr.inc:133:Error [103] syntax error mios_isr.inc:138:Error [103] syntax error mios_isr.inc:174:Error [103] syntax error mios_isr.inc:205:Error [103] syntax error
These errors are caused by a nice Feature from mpasm – you can pass instructions as Macro argument. Unfortunately, gpasm has (at least right now) no support for this, so i wrote a small quick&dirty script, that changes all these MACROs to the appropriate syntax. To use this script, copy the following to files in your mios_v_1_x_src dir:
replace-macros.sed:
1i;hey emacs, this is -*- asm -*- /^[ \t]*;/b #skip commented line /^\s*\w*\s*MACRO/b #skip macro definitions s/\<BIFSET\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\([^,]*\)\s*,\s*\(.*\)/btfsc \1, \2, \3\n\t\4/g s/\<BIFCLR\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\([^,]*\)\s*,\s*\(.*\)/btfss \1, \2, \3\n\t\4/g s/\<IFSET\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\(.*\)/btfsc \1, \2\n\t\3/g s/\<IFCLR\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\(.*\)/btfss \1, \2\n\t\3/g s/\<IFNEQ\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\(.*\)/cpfseq \1, \2\n\t\3/g s/\<IFLEQ\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\(.*\)/cpfsgt \1, \2\n\t\3/g s/\<IFGEQ\s*\([^,]*\)\s*,\s*\([^,]*\),\s*\(.*\)/cpfslt \1, \2\n\t\3/g s/\<rgoto\>/bra/g
fix-gpasm.sh:
#!/bin/sh
for i in src/*.inc src/*.asm src/*.h;do
tr -d '\r' < $i|sed -f replace-macros.sed >${i}_ && mv ${i}_ $i
done
Now you can run ./fix-gpasm.sh, which replaces all the problematic macros.
compiling_the_midibox_source_on_linux.1143905337.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
