DAW-Encoder-Display - Board
I made this PCBs to use it with Latigid-Ons display_driver
It is one part to build a DAW-controller, it can be used multiple times
Here are the gerberfiles for production - i made it withJLCPCB
daw-encoder-display-gerber.zip
testet - working fine!
https://youtu.be/XFh9ZhL0jhE
Shematic
Building and BOM
The Values are printet on the PCB.
Following Quantity is for 1 PCB, Mouser:
open following link: https://www.mouser.com/tools/part-list-import.aspx
& copy past follwong list:
187-CL21B104KBFWPJE|7
187-CL21A106KPFNNNE|4
81-GRM219R60J476ME4D|4
652-PEC11R-4015F-S24|9
710-61201021621|3
667-ERJ-P06F1001V|6
660-RK73H2ATTD1002F|27
660-RK73H2ATTD1002F|3
You may change the how many times you want to order this project
aka you need it 10 times, then do this after importing the list into mouser…
if you need it 10 times it cost around 199€
6 Displays which you get from Ali:
SSD1306-128x64 7pin White
To Do
make a Frontpanel.
Community users working on it
or join the forum: daw-controller-ableton
