dipboardf4
dipBoardF4
MIDIbox Hardware Platform extension for dipCoreF4.
Features
- Very small size 65x46mm(less than your credit card).
- Very low profile.
- Your application board can be stacked on bottom with 'Micro-match' connectors.
- The dipCoreF4 can be installed on the two side.
- Provides all the most important features and ports as a regular mbhp.
Dimension
PCB
Ports and features.
toDo
Compatible/stack-able boards options
- M16 Interface, stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO
toDo
dipboardf4.1536089545.txt.gz · Last modified: 2018/09/04 19:32 by antichambre
