displaydriver-smd
Display Driver - Board - for 18 SSD1306 Screens
this is one essential part for my triggermatrix5
I need there 18 Display, and i had good expierence with andys display_driver-board
i created this board. its fully SMD, and made it pick and place ready - so no soldering required!
Shematic
Building and BOM
The Values are printet on the PCB.
blm16x16-pcb-back.pdf
blm16x16-pcb-front.pdf\\
BOM v1.0
| Comment | Designator | Footprint | LCSC |
| 10uF | C1-18,C34-54 | 0805_C | CL21A106KAYNNNE |
| 100n | C19-33 | 0402_C | C307331 |
| - | CS1,LCD1-18,inB10,outB10,in15 | PinHead-SMD-2,54mm Pitch | C192300 |
| SN74HC541 | IC1-7 | SOIC127P780X200-20N | C116811 |
| 74HC595 | IC8-10 | SOIC-16 | C5947 |
| 220 OHM | R1-54 | 0402_R | C25091 |
| 1K OHM | R55-96 | 0402_R | C11702 |
To Do
Order the Prototype, waiting for christmas….
Community users working on it
or join the forum: daw-controller-ableton
displaydriver-smd.1671936104.txt.gz · Last modified: 2022/12/25 02:41 by phatline
