displaydriver-smd
Display Driver - Board - for 18 SSD1306 Screens
this is one essential part for my triggermatrix5
I need there 17 Displays, and i had good expierence with andys display_driver-board
since i didnt want to solder this board by hand again - i created this board. its fully SMD, and made it pick and place ready - so no soldering required!
Shematic
Building and BOM
Follwing list is for reference, and debugging only, no need to order them! all the parts are already soldered on the PCB!
BOM
| Comment | Designator | Footprint | LCSC | |
| 10uF | C1-18,C34-54 | 0805_C | CL21A106KAYNNNE | |
| 100n | C19-33 | 0402_C | C307331 | |
| - | CS1,LCD1-18,inB10,outB10,in15 | PinHead-SMD-2,54mm Pitch | C192300 | |
| SN74HC541 | IC1-7 | SOIC127P780X200-20N | C116811 | |
| 74HC595 | IC8-10 | SOIC-16 | C5947 | |
| 220 OHM | R1-54 | 0402_R | C25091 | |
| 1K OHM | R55-96 | 0402_R | C11702 | |
| 22 | IDC-Connector | 2x4Pin | IDC | 710-61200823021 |
Order-List
To Do
waiting for the assembled Prototype
Community users working on it
displaydriver-smd.1672260630.txt.gz · Last modified: 2022/12/28 20:50 by phatline
