dougwellington_marquardt_switch_bulk_order
Marquardt 6425 Series Switch Group Buy
This bulk order is for Marquardt 6425 series switches. These are the same switches that are used in the Monodeck II. You can see details of these switches at Marquardt Tact Switches Web Page. I ordered some samples of these switches - you can see some pictures at my MIDIbox Addict Parts Page.
Switches are available with an LED in the corner or without an LED. The switches with no LED are almost a dollar cheaper than the ones with the LED!!! LEDs are a lot cheaper than a buck, so I can't see buying the ones with the LED… (The switches themselves are identical.) Caps are available with and without holes for an LED.
The switches should be no more than $1.50 (US Dollars), the caps with no LED holes will be no more than $.30 each, and the caps with LED holes will be no more than $.50 each. My distributer has the switches and the no-LED caps in stock, but the caps with LED holes have an eight week lead time. Once the order is placed, I'll be able to put an “expedite” request in to see if we can get them faster…
Click on the “Edit this page” button (top left corner) and add your MIDIbox username and the number of switches and caps you would like.
ADD YOUR NAME AND QUANTITY TO THE END OF THE LIST
DO NOT DO ANY OTHER EDITS TO THIS PAGE
Adding your username and quantity is not a commitment to purchase them if/when I have them available to sell, however, if you change your mind, please come back here and change/remove your list entry.
UsernameSwitch QuantityCap (no LED) QuantityCap with LED Hole Quantity
Doug Wellington644816
PHATTLINE64064 I am also Interestet with Printing on it “1” to “8” (8×1, 8×2, 8×3…..8×8) or “1” to “16”
moogah1008416
boops30300
Total : 25812696
dougwellington_marquardt_switch_bulk_order.1228085430.txt.gz · Last modified: 2008/11/30 22:50 by boops
