MB-6582 Panels
NEWS - October 2008
1) After getting prices on panels for several projects, it turns out to be cheaper if I buy my own CNC mill and do them all myself!
2) I am also purchasing a concealed head stud insertion machine so that I will be able to install studs and standoffs on the back of the panel - no JB Weld required. This will add extra cost to the panel, but will save everyone a lot of time and trouble.
3) Since I have all the silk screen tools already, I am adding the option for either red or blue lines on the panel.
4) If you do not have a PT-10 case already, I can provide one for you. Please let me know if you want me to use the PT-10 panels or make one from scratch. The PT-10 panels will have the four mounting holes in the corners, while the ones I make from scratch have no exposed hardware on the front.
DETAILS
I will make top and back panels for your MB-6582 or re-silkscreen panels you already have. The panels I am making will be black anodized, with two color silkscreen, white lettering with either red or blue lines separating the sections of the panel. I will be installing concealed head standoffs so that you can bolt the control surface circuit board directly to the back of the panel. If I make a new panel for you (not using the one included with the PT-10 case), I will install concealed head studs in the four corners for mounting the panel to the case.
How To Sign Up For A Set Of New Panels
If you want to get a panel set, click on the “Edit this page” button (top left corner) and add your MIDIbox username and the number of panel sets you would like, what color the lines should be, and whether you need a PT-10 case. If you want a PT-10 case, tell me if you want the corner holes or not - if you don't want corner holes, I will make a new panel for you. (And if you don't want the original panels, I will keep them and discount the PT-10 case price.)
ADD YOUR NAME AND QUANTITY TO THE END OF THE LIST
DO NOT DO ANY OTHER EDITS TO THIS PAGE
Adding your username and quantity is not a commitment to purchase them if/when I have them available to sell, however, if you change your mind, please come back here and change/remove your list entry.
| Username | Quantity | Line Color | Need PT-10 | Corner holes? | Comment |
| Doug Wellington | 2 | 1 red, 1 blue | 2 | no | |
| asafnetzer | 1 | red | wood | no | |
| audioguru42 | 1 | red | 1 wood | no | |
| Johnniebee | 2 | 1 red, 1 blue | wood x 2 | No | |
| 23 | 1 | ||||
| stevenclements | 1 | ||||
| tarzan boy | 1 | red | 1 wood | no | |
| NV | 1 | White | Wood | No | |
| Sparx | 1 | ||||
| kaio | 1 | ||||
| BaconJuice | 2 | 1 white, 1 blue | No | No | |
| necro2607 | 1 | ||||
| kk74 | 1 | blue | 1 | no | |
| Strophlex | 1 | red | 1 wood | no | |
| Gajimicu | 1 | blue | 2 | please use original pt-10 panels | |
| droopydnl | 3 | 3 | |||
| buhler | 2 | 1 red,1 blue | 2 | yes if cheaper, no if not | |
| madox | 1 | red | 3 | no | |
| Acidlad | 1 | ||||
| mememamo | 2 | red | 1xpt10 1xwood | yes | |
| moonfaze | 1 | ||||
| illiac | 1 | ||||
| plasticeyes | 1 | blue | no | no | |
| uberLAB | 2 | 1 RED, 1 BLUE | 1 WOOD | NO | |
| Junkyseb | 1 | ||||
| Koshimazaki | 1 | red | 1 wood | no | don't need original panel |
| LoopStar | 1 | ||||
| eDrakeeee | 1 | blue | 1 | yes | |
| maxvl | 1 | ||||
| aminoplacid | 1 | red | 1 | no | |
| Snoozr | 1 | red | 1 | no | don't need original panel |
| xarolium | 1 | ||||
| polpat | 1 | red | 0 | no | |
| Futureman | 1 | white | 0 | ||
| sensorium | 3 | 1 red, 2 blue | black X 2 wood X 1 | No | |
| slapyak | 1 | ||||
| dougmoser | 1 | ||||
| foona | 1 | red | no | yes | |
| frailn | 1 | red | no | no | |
| subatomic | 1 | red | yes | don't i need holes? whatever fits best… | |
| boops | 1 | blue | 1 wood,+1 pt 10 black | no | |
| Peake | 1 | red | no | ||
| dnode | 1 | ||||
| ganchan | 1 | (white) blue | yes | no | |
| KnowGood | 1 | red | 1 | no | |
| xyc0n | 1 | ||||
| Scipher | 1 | ||||
| vout | 1 | red | 1 | no | |
| Berg | 1 | red | 0 | no | |
| DenDer | 2 | ||||
| j00lz | 2 | red | 0 | no | |
| dioioib | 3 | white | 5x wood | ||
| Duchy | 1 | white if possible, otherwise blue | wood | no unless cheaper | |
| kokoon | 1 | ||||
| seekwhensir | 2 | ||||
| fabioldr | 3 | ||||
| ping- | 5 | 3 red, 1 green, 1 white | 1 wood | no | |
| 1 | Blue | 1 | yes if cheaper, no if not | ||
| amorphiss | 1 | ||||
| filch | 1 | blue | 1 | no | no original panel,Req all white panel w/ blue lettering |
| kawill | 1 | ||||
| reemus | 4 | ||||
| goldbug | 1 | red | wood | no | |
| dendy | 1 | ||||
| m00dawg | 1 | Red | 1 | Whichever is cheaper | |
| jimh54 | 1 | red | 1 | no | |
| jbutron | 1 | ||||
| SIDsyndrome | 1 | ||||
| Matrix12x | 1 | red | wood | ||
| Phattline | 2 | white | 2 | yes | silkscreening |
| note repeat | 1 | ||||
| flexinoodle | 3 | 1x Red 2x Blue | 2x Wood | No | don't need original panel |
| Harbinger | 1 | ||||
| skyline7 | 1 | ||||
| drakeeee | 1 | red | yes | ||
| dreamer | 2 | 1xRed 1xBlue | 1xpt10 1xwood | No | |
| Walle | 1 | ||||
| Tarzan Boy | 1 | ||||
| Echopraxia | 1 | ||||
| insky | 1 | ||||
| Xenon23 | 2 | blue | 2 | no | |
| sonofprent | 1 | ||||
| mrcam | 1 | 1 | no unless cheaper | shipping with Gamijicu | |
| Natsirt | 2 | 1 red/1 blue | 2 | no | |
| g.p.macklin | 1 | ||||
| ascarrul | 1 | ||||
| edanderson | 1 | ||||
| toucanalog | 1 | red | wood | no | |
| bleepsnbreaks | 2 | 1 red, 1 grey (if possible, white if not) | wood | no | |
| 3rdordertrauma | 1 | ||||
| do0g | 2 | ||||
| Flemming | 1 | red | no | no | |
| theprotool | 1 | 1xred | yes | no | |
| Narwhal | 1 | blue | no | no | |
| Snebenan | 1 | ||||
| Enth | 1 | blue | no | no | |
| bugfight | 1 | red | wood | no | |
| booster | 2 | red | no | no | |
| reboot | 3 | 2 blue + 1 red | 2 boxes | ||
| MP | 1 | blue | 1 | no | |
| veau | 1 | blue | 1 | no | |
| mmalluck | 1 | red | 1 | yes | |
| do0g | 2 | white | no | no | |
| idiotcountry2 | 1 | red | wood | no | |
| Echopraxia | 1 | red | 1 | no but yes if way cheaper | |
| bron84 | 1 | red | 1 wood | no | |
| Acid303 | 1 | blue | no | yes | |
| pavel | 2 | red | 2 | no but yes if cheaper | |
| PimpinBassie | 1 | blue | 1 | no | |
| KB2142 | 1 | blue | 1 | no | |
| casius | 1 | white | 1 | no | don't need original PT-10 panel |
| hantymansy | 2 | blue | 2 | no | |
| perdex | 1 | blue | 1 | no | |
| ampman117 | 1 | red | yes | yes | |
| Serge_D | 1 | red | no | no | |
| SubContractor | 1 | white | dont know yet | dont know yet | |
| hutch1980 | 1 | blue | 1 | no | Don't need original panel |
| highrider | 1 | white | wood | don't need original PT-10 panel | |
| SysEx | 1 | red | 1 | no | |
| Snyderman | 1 | white | 1 | no | don't need original panel |
| biroute | 1 | blue | 1 | no | don't need original PT-10 panel |
| dukankallemegper | 1 | white | no | no | |
| bamsyn | 3 | Red | NO | no | |
| Thirstmonkey | 2 | 1 x red 1 x White if possible | 1 x pt10 1 x wood | NO | don't need original panel |
| laban | 1 | blue | 1xPT10 | No | |
| widdly | 1 | red | 1 | No | |
| kroutshev | 2 | red | yes | yes | don't need original panel |
| St.Eligius | 1 | red | 1 | yes | |
| Valant | 1 | blue | No | N/A | |
| jooks | 1 | white | wood | no | don´t need the original panel |
| 1010 | 0 | N/A | 2 wood | N/A | no but yes if cheaper |
| son green | 3 | 2 blank, 1 white | 2 wood, 1 black | no | don't need original panel |
| swindus | 1 | red | 1 | yes | don't need original PT-10 panels |
| mattflo | 2 | 1 red, 1 blue | 2 | no | don't need original PT-10 panels |
| newnumbertwo | 1 | red | 1 wood | no | don't need original panel |
| sakodak | 1 | red | 1 | no | don't need original panel |
| visibleman | 1 | red | 1 | no | don't need original panel |
| nestle | 1 | red | 1 wood | don\t need original panel | |
| vcfool | 1 | blue | 1 black | no | don't need original panel |
| dar2dar2 | 1 | red | no | yes | |
| baboon1346 | 1 | red | no | no | |
| soundklinik | 1 | red | yes | yes | |
| esquilax | 1 | blue | wood | no | would like to see what 'wood' looks like first. :) |
| Morten | 1 | blue | no | no holes | |
| weedoo | 1 | red | 1 | no | don't think I need original panel, do I ? |
| edlikestoboogie | 1 | red | 1 | no | I don't need the original panel, please make from scratch |
| drboom | 2 | 1 red, 1 blue | no | no | |
| curve | 1 | red | 1 | no | |
| trehune | 1 | white | 0 | no | |
| sonofdirt | 1 | blue | wood | no | wood(alder?) pending cost-effectiveness |
| lead bromide | 1 | blue | 1 | no | |
| dschohennes | 1 | white | 1 | no, unless much cheaper | |
| locoder | 2 | red | 2 | no | don't need original panel |
| senis | 1 | red | no | no | |
| kok6 | 1 | blue | 1 | yes | |
| CaptainCoconut | 1 | red | yes | no | don't need original panel |
| hb129 | 2 | ||||
| juhnumoffa | 1 | red | yes | no | don't need original panel |
| Rave | 1 | red | 1 | no | Don't need original panel |
| audio-mobster | 1 | red | 1 wood | no price? | Where can I see the wood case? |
| Naturebot | 1 | blue | yes | whatever is cheapest option :) | |
| iamlark | 1 | blue | yes | whichever is cheaper | |
| Levon | 1 | blue | yes | whichever is cheaper | |
| lunchweek | 1 | blue | 1 | no | |
| hermes | 1 | red | 1 | No | don't need original panel |
| TOTAL | 215 | X | X | X | (Don't worry about this, I'll total it all up later. -Doug) |
