dout_module
General Informations
A DOUT module is a digital output module, usually used to drive LEDs with a Midibox.
- DOUT Module uCApps
Note that hardware pin's will be counted D7 - D0 / O7 - O0 / QH - QA. In contrast, pins for DIN modules will be counted D0 - D7.
Refer the DIN & DOUT Pintable to see the relation between software pin numbers and hardware pins.
Connection to Core Module
Check the version of your Boards; if you’re using SmashTV’s Core that’s equipped with double rows, you can build a split-cable to connect J8/J9 to a DIN and a DOUT:
dout_module.1310629920.txt.gz · Last modified: 2011/07/14 07:52 by rahulmitchell1
