gm5x5x5_-_allied_parts_list
GM5x5x5 Allied Electronics Parts List
Note that I have not yet purchased these items but will do so in the near future. Until I confirm these are good, use at your own risk.
Item | Allied Stock # | Qty | Notes | ||
Crystal (16Mhz) | 895-0691 | 1 | |||
LED 3mm (Red) | `670-1058 | 11 | They are expensive and I don't know what resistor value you might need. By these from SmashTV instead) | ||
Diode | 935-0242 | 5 | |||
Optocoupler | 787-0137 | 5 | |||
Hex Inverter | 236-1747 | 5 | |||
USB Type B Socket | 374-0052 | 1 | |||
MIDI Socket | 932-0200 | 10 | These look right, though are a bit pricey and perhaps not as cool as you could find elsewhere | ||
40-pin breakaway headers | 374-1768 | 1 | |||
EEPROM | N/A | 0 | I didn't use one and I also coudln't find a 24C04 specifically in a DIP package | ||
Resistor - 220 Ohm | 296-4751 | 15 | |||
Resistor - 1K Ohm | 296-4741 | 18 | |||
Resistor - 27 Ohm | 296-4759 | 1 | |||
Resistor - 4.7k Ohm | 296-4769 | 1 | |||
Capacitor - 100nF | 507-0211 | 6 | |||
Capacitor - 10uF | 613-0124 | 1 | |||
Capacitor - 22pF | 507-0201 | 2 | |||
Capacitor - 1uF | 507-0606 | 1 | |||
Jumper | 863-0403 | 5 | |||
Total | $37.37 |
gm5x5x5_-_allied_parts_list.1269826388.txt.gz · Last modified: 2010/03/29 01:33 (external edit)
