gm5x5x5_errata
This page lists the know errors on the gm5x5x5 PCBs.
Prototype Run
#1 MIDI IO pins
Problem: The MIDI IO pins of the midi sockets (Pin 4 + 5) are switched.
Solution: Either (1) use the pin-headers if you use sockets that are not mounted on the pcb or (2) break the traces to pins 4 + 5 of the sockets and solder wires to them or (3) solder the midi sockets on the other side of the pcb.
gm5x5x5_errata.1227390498.txt.gz · Last modified: 2008/11/22 21:48 by fossi.bs
