MIOS supports internally Hitachi HD44780 compatible character displays
It's 'so called' industry standard for character displays, but not all “standard” displays have this particular chip.
HD44780 compatible LCD controllers:
| Controller: | Manufacturer: |
| HD44780 | Hitachi |
| KS0066 | Samsung |
| KS0076 | Samsung |
| KS0070 | Samsung |
| S6A0069 | Samsung |
| LC7985NA | Sanyo |
| SED1278 | Epson |
| NT3881D | Novatek |
| SPLC780 | Sunplus |
| MSM6222 | OKI |
| NJU6408B | NJR |
| NJU6468 | NJR |
| NJU6470 | NJR |
| Probably: | |
| UM3881B 1) | UMC |
| T7934 2) | Toshiba |
If your LCD has one of these chips, there are good changes to get it work. These chips have similar instruction set, data bus and timings are like original HD44780 (or faster, which shouldn't matter)
BUT this only means that controller chip is compatible with driver designed to HD44780
It's simply easier to get a display, that has datasheet available.
Common problems, if it isn't your soldering:
First: There is no common standard for display connector - You should get your LCDs datasheet to see what the pinout is.
Second: Your display may need negative contrast voltage. (Watch out for Vee pin.) (Usually found in 'extended temperature range' displays)
Third: Backlight not working? Maybe it's Electroluminescent (EL) type. (might need 'so called' inverter circuit to drive backlight)
And it's also good to know, at least HD44780 displays can be initially programmed to different character sets - maybe your dirt cheap surplus display just talks greek to you
