home:mbhp:module:bootloader-switch
BootLoader-Switch
when activated it will force Core32 to bootup in Bootload mode, doesnt matter how buggy your progam is…
you need:
2x wires
2x 2Pin-Header
On-OFF Switch
solder this like in this Picture:
and connect it to following pins:
you maybe not need this, but when you need it, its good to have such switch on the backside of your midibox (@least when uploading, buggy betas, or you code your own program…)
home/mbhp/module/bootloader-switch.1522613328.txt.gz · Last modified: 2018/04/01 20:08 by phatline
