home:mbhp:module:core32
MBHP Core STM32
About
aka Core32 This page very incomplete as this is still in development All about the module
Getting Started
Special Instructions
Details
Pin out list
list it
PCB files
list 'em
Schematic
you can do it
List of parts
list
(Source: MBHP CORE_32 Orderlist from http://mbhp.avishowtech.com 2009/09/10)
Description | Qty | Mouser Part # | Digi-Key Part # |
Voltage Regulator 7805 | 1 | 511-L7805CV | |
Voltage Regulator LF33 | 1 | 511-LF33CV | 497-7313-5-ND |
Optocoupler 6N138 | 2 | 512-6N138 | 6N138QT-ND |
IC-Sockets for Optocoupler | 2 | 571-1-390261-2 | 3M5473-ND |
Diode 1N4148 | 3 | 78-1N4148 | 1N4148FS-ND |
Transistor BC337 | 1 | 512-BC33725TA | BC33725TACT-ND |
74HC595 | 1 | 595-SN74HC595N | |
IC-Socket for 74HC595 | 1 | 571-1-390261-4 | 3M5475-ND |
Crystal 12 MHz | 1 | 815-ABL-12-B2 | |
Ceramic Cap 33 pF | 2 | 140-50N5-330J-RC | 399-4172-ND |
Ceramic Cap 100 nF | 9 | 21RZ310-RC | |
Ceramic Cap 330 nF | 1 | 80-C320C334M5U | |
Polarised Capacitor 10 µF 25v | 1 | 140-HTRL25V10-RC | |
Polarised Capacitor 47 µF 25v | 1 | 140-HTRL25V47-RC | |
Polarised Capacitor 100 µF 16v | 1 | 140-HTRL16V100-RC | |
Polarised Capacitor 2200 µF 16v | 1 | 140-HTRL16V2200-RC | |
Resistor 100 kΩ | 1 | 291-100K-RC | |
Resistor 10 kΩ | 2 | 291-10K-RC | |
Resistor 4.7 kΩ | 2 | 291-4.7K-RC | |
Resistor 2.2 kΩ | 2 | 291-2.2K-RC | |
Resistor 1 kΩ | 5 | 291-1K-RC | |
Resistor 470 Ω | 1 | 291-470-RC | |
Resistor 220 Ω | 6 | 291-220-RC | |
Resistor 27 Ω | 2 | 291-27-RC | |
Resistor Network 4*10 kΩ | 1 | 652-4605X-1LF-10K | 4605X-101-103-ND (non-stock) |
Resistor Network 4*1 kΩ | 3 | 652-4605X-1LF-1K | 4605X-101-102-ND (non-stock) |
Resistor Network 4*220 Ω | 1 | 652-4605X-1LF-220 | 4605X-101-221-ND (non-stock) |
TrimPot 10 kΩ | 2 | 531-PT6KV-10K | |
Green Status LED | 1 | 859-LTL-4232N | |
Bridge Rectifier | 1 | 625-W06G-E4 | |
USB Socket B-Type | 1 | 649-61729-1010BLF | |
PCB MIDI sockets | 4 | 161-0504-E | |
2×5 DIL Headers | 7 | 517-30310-6002 | |
2×8 DIL Headers | 2 | 517-30316-6002 | |
2×10 DIL Header | 1 | 517-30320-6002 | |
1-row SIL Headers (about 20 pins) | 1 | 517-6111TG | |
1-row SIL socket (3 * 5 pins) | 1 | 517-984-01-05 | |
Jumpers | 6 | 151-8033-E |
STM32
F103RB
- About
- Basic Specs
- Pros/Cons
F103RE
- About
- Basic Specs
- Pros/Cons
Building it
Building instructions
blah blah blah
Testing
testing instructions
Common issues / Troubleshooting
blah blah blah
if you upload bug-code, and you cant get a usb connection to upload new code then make a:
- Bootloader-Switch , activated it forces Core32 to bootloader mode.
References
home/mbhp/module/core32.txt · Last modified: 2018/04/01 20:02 by phatline
