home:software:picasm
PIC ASM
Here you can find tips, tricks, tutorials and documentation concerning the Microchip PIC assembler language.
Tips & Tricks, Questions and Answers
How to locate two lables at the same memory position?
If you want to export a label for C applications, and you want to use the same name for the variable in C and ASM, you can do this in the way shown here (for example in module_xxx.asm):
global VAR1 global VAR2 global _VAR1 global _VAR2 MY_VARS UDATA _VAR1 RES 0 VAR1 RES 1 _VAR2 RES 0 VAR2 RES 1
This will put _VAR1 / VAR1 at the same memory position. Never put the _VAR1 RES 0 *after* VAR1 RES 1! This would cause the assembler to give _VAR1 an address, but would not reserve any memory for it!
Also refer this discussion in the forum: http://www.midibox.org/forum/index.php/topic,12846.0.html
home/software/picasm.1232502089.txt.gz · Last modified: 2009/01/21 01:41 by this
