Midibox CV to extend “DOUTs”
Anyone who considers 2 or 8 gates too few, or wants to trigger vintage drum synths/modules (Roland x0x style), may find the existing hardware of the Midibox CV insufficient. The solution is simple.
Hardware
A dout module is needed, which will be connected to J8 of the coremodule. A doutx4 provides 32 gates/triggers. Some advice at this point: because it will be built without any optocouplers or transistors to protect the DOUT, it is essential not to apply any external voltage to the Gates/Triggers, and also to prevent short circuit.
Software
A few changes have to be made to the sourcecode. On the one hand, the dout has to activate the gate/trigger on receiving the appropriate NoteOn: on the other hand you may want to reduce the duration of an impulse to 1ms independent of the Note duration.
Here as background is the trigger characteristic of some drum machines. The x0x-boxes (606,808,909…) trigger the sound at decrease of voltage at the gate instead of increase. (IE at the trailing edge of the +ve pulse rather than the leading edge? Wikipedia says that Roland and Sequential gear is V-Trig {normal low, set high to trigger} and Moog, Korg and Yamaha is S-Trig {normal high, set low to trigger}.)
Activate dout:
Download the source of Midibox CV at http://www.ucapps.de/mios_download.html and search for the following in “main.asm”:
USER_MPROC_NotifyReceivedEvent ;; process MIDI event call CV_MIDI_NotifyReceivedEvent ;; for best latency: branch to USER_Tick so that the new CV values ;; will be mapped immediately rgoto USER_Tick
Replace it with:
USER_MPROC_NotifyReceivedEvent ;; BEGIN --- control DOUT pins via Note events at channel #1 movf MIOS_PARAMETER1, W ; Note Off -> Note On with velocity 0 andlw 0xf0 xorlw 0x80 bnz USER_MPROC_NRE_NoNoteOff USER_MPROC_NRE_NoteOff bsf MIOS_PARAMETER1, 4 clrf MIOS_PARAMETER3 USER_MPROC_NRE_NoNoteOff movlw 0x90 ; check for Note On at channel #1 IFNEQ MIOS_PARAMETER1, ACCESS, rgoto USER_MPROC_NRE_NoNoteChn1 USER_MPROC_NRE_NoteChn1 ;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 movf MIOS_PARAMETER3, W ; velocity == 0: off, velocity != 0: on skpz movlw 0x01 movwf MIOS_PARAMETER1 movf MIOS_PARAMETER2, W ; pin number: note number - 0x24, we start with C-2 addlw -0x24 andlw 0x7f call MIOS_DOUT_PinSet USER_MPROC_NRE_NoNoteChn1 ;; END --- control DOUT pins via Note events at channel #1 ;; process MIDI event call CV_MIDI_NotifyReceivedEvent ;; for best latency: branch to USER_Tick so that the new CV values ;; will be mapped immediately rgoto USER_Tick
What happens here? Midibox CV is listening to the first channel (beginning from tune C-2) for a NoteOn and activates the corresponding dout. A NoteOff deactivates the dout.
1ms Extension For Vintage Drum Machines:
Those who want to trigger vintage drums have to modify the sourcecode as follows: Search for the following:
USER_SR_Service_Finish ;; ---[ handle with control surface variables (flashing cursor, etc) ]--- goto CS_MENU_TIMER
Replace it with:
USER_SR_Service_Finish clrf MIOS_PARAMETER1 movlw 0x00 call MIOS_DOUT_SRSet movlw 0x01 call MIOS_DOUT_SRSet movlw 0x02 call MIOS_DOUT_SRSet movlw 0x03 call MIOS_DOUT_SRSet ;; ---[ handle with control surface variables (flashing cursor, etc) ]--- goto CS_MENU_TIMER
This leads to a reset of all DOUTs once per cycle - this lasts 1ms. So the drum modules can be triggered with a 1ms latency.
(Would it be possible to code for S-Trig as well - having the DOUT pins held normally high, and drop to 0v on NoteOn? - Bunsen)
Forum articles:
http://www.midibox.org/forum/index.php?topic=2701.0
http://www.midibox.org/forum/index.php?topic=6333.0
