howto:dev:libcan
FIXME Elaborate…
Using libcan
What is libcan ?
libcan is library to use the ECAN feature of the PIC18F2682/2685/4682/4685. CAN (for Controller Area Network) is a communication bus for micro-controllers and, hence, enables easy communication between CAN-enabled PIC micro-controllers, such as th PIC18F4685.
Announcement forum post: http://www.midibox.org/forum/index.php?topic=10338.0
libcan has nothing specific to MIOS so you could also use it outside MIOS.
Requirements
libcan uses the AutoTools application skeleton. So if you want to recompile it, you need all the related stuff.
The examples in this page also uses the AutoTools application skeleton.
CAN Wirings
Here we describe some CAN wirings.
Single wire CAN
Dual wire CAN with MCP2551 transceiver
Getting started with libcan
Message flows overview
Initialize CAN
You first have to initialize the CAN module of the PIC. This is done via the can_init() function of libcan.
void can_init();
Sending a message
Sending a data message is done via the can_transmit_data(…) function.
can_transmit_buffer_control * can_transmit_data(unsigned char local_id, unsigned char priority, unsigned char length, data_ptr data_field);
libcan then processes the message in the following way :
  1. Select a message transmit buffer
  2. Convert the application-local message ID to the corresponding bus-global message ID
  3. Fill the message buffer with the global ID and data
  4. Order the PIC to send the message
Receiving messages
Dispatching of data messages is done via the can_dispatch() function.
void can_dispatch(void);
Selected messages are then forwarded to the application via the can_receive_data_handler() user handler.
extern void can_receive_data_handler(unsigned char local_id, unsigned char length, data_ptr data_field);
Thus to receive messages, one has to call the can_dispatch() from its main loop (say, for MIOS, in the Tick() user handler), and implement the can_receive_data_handler() function.
libcan processes incoming data messages in the following way :
  1. Fetch receive buffers until none is full
    1. Select a full receive buffer
    2. Convert the bus-global message ID to the corresponding application-local message ID
    3. If this id has been recognized, call can_receive_data_handler() with the local ID and data
    4. Empty the receive buffer
Message IDs
Local IDs are specific to the application. They are the IDs the application uses to reference the types of message it can send and receive.
Global IDs are bus-wide. They are the IDs that are communicated through the bus.
Local IDs are unsigned chars whereas global IDs are of type can_id_t, a specific PIC-optimized representation of IDs. You can create can_id_t instances by using the provided CAN_STD_ID(id) and CAN_EXT_ID(id) macros.
#define CAN_STD_ID(id) \
	(can_id_t) ... // preprocessing of id to make it a standard ID
#define CAN_EXT_ID(id) \
	(can_id_t) ... // preprocessing of id to make it an extended ID
In fact, the can_id_t structure is an unsigned long typedef. However it does not contain a simple unsigned long. The ID is split in a standard and an extended part conforming to the CAN specification, and arranged in a manner suitable to direct consumption by the PIC micro-controller.
libcan uses local IDs to enable easy maintainability of the application. Thus one can change the local IDs or the global IDs independently. That is neat if you have many different applications that needs to communicate over a CAN bus. Also local/global mapping could be changed dynamically, thus enabling reconfiguration of the CAN nodes when a new CAN node enters the bus (see libcannelloni for an example of dynamic reconfiguration of the CAN network).
Conversion between local and global IDs are done via the can_local_to_global_id(…) and can_global_to_local_id(…) user handlers.
extern can_id_t can_local_to_global_id(unsigned char local_id);
extern unsigned char can_global_to_local_id(can_id_t internal_id);
The library provides three helper functions can_helper_table_ltog(…), can_helper_table_gtol(…) and can_helper_bdt_gtol(…) to ease the implementation of the user handlers.
can_id_t can_helper_table_ltog(unsigned char local_id,
		const can_id_mapping_element_t const mapping_table[]);
unsigned char can_helper_table_gtol(can_id_t internal_id,
But let's jump into some examples, and you'll better understand the big picture…
Sending message example
In this example, we send a message for each change of the first encoder of the first shift register.
#include <cmios.h>
#include <can.h>
/* Encoder definition table */
MIOS_ENC_TABLE {
		MIOS_ENC_ENTRY(1, 0, MIOS_ENC_MODE_DETENTED3),
		MIOS_ENC_EOT
/* Message ID definitions */
#define ENCODER_CHANGE 1
const can_id_mapping_element_t outgoingMessageIDs[] = {
		{ENCODER_CHANGE, CAN_STD_ID(10)}
/* Application code */
void Init(void) __wparam
	MIOS_SRIO_UpdateFrqSet(1);
	MIOS_SRIO_NumberSet(1);
	MIOS_SRIO_DebounceSet(0);
	MIOS_ENC_SpeedSet(0, MIOS_ENC_SPEED_FAST, 2);
	can_init();
typedef __data struct {
	unsigned char id;
	char incrementer;
} encoder_change_message_t;
encoder_change_message_t encoderChangeMessage;
void ENC_NotifyChange(unsigned char encoder, char incrementer) __wparam
	can_transmit_buffer_control_t * bc;
	encoderChangeMessage.id = encoder;
	encoderChangeMessage.incrementer = incrementer;
	bc = can_transmit_data(ENCODER_CHANGE, 0,
			sizeof(encoder_change_message_t),
			(data_ptr) &encoderChangeMessage);
	return can_helper_table_ltog(local_id, outgoingMessageIDs);
The important bits of this example could be summarized as follows :
  1. We create an outgoingMessageIDs table with a single message with local ID 1 and global ID 10
  2. We init the CAN module in our Init() user handler
  3. We define a structure for the message data and instanciate it for the current message pending transmission
  4. In the ENC_NotifyChange() user handler, we send a message by calling can_transmit_data() with the following arguments :
    • The message local ID : ENCODER_CHANGE
    • The message priority (among other messages to send) : 0
    • The size of the data to send : sizeof(encoder_change_message_t)
    • The data itself : (data_ptr) &encoderChangeMessage);
  5. We convert local to global IDs in the can_local_to_global_id() by using the helper function can_helper_table_ltog() and our outgoingMessageIDs table.
Receiving messages example
In the following example, we receive messages that tells us to toggle DOUT pins.
#include <cmios.h>
#include <can.h>
#define DOUT_TOGGLE 1
const can_id_mapping_element_t incomingMessageIDs[] = {
		{DOUT_TOGGLE, CAN_STD_ID(40)}
	can_init();
	unsigned char id;
	unsigned char value;
} dout_toggle_message_t;
void doutToggle(dout_toggle_message_t * doutToggleMessage)
    MIOS_DOUT_PinSet(doutToggleMessage->id, doutToggleMessage->value);
void Tick(void) __wparam
	can_dispatch();
	switch (local_id) {
		case DOUT_TOGGLE:
			doutToggle((dout_toggle_message_t *) data_field);
			break;
		default:
			break;
unsigned char can_global_to_local_id(can_id_t global_id)
	return can_helper_table_gtol(global_id, incomingMessageIDs);
  1. We create an incomingMessageIDs table with a single message with local ID 1 and global ID 40
  4. In the Tick() user handler, we call can_dispatch() to let libcan process incoming messages
  5. In the can_receive_data_handler() user handler, we fetch the local_id and call the corresponding function to process the message data casted adequately
  6. We convert global to local IDs in the can_global_to_local_id() by using the helper function can_helper_table_gtol() and our incomingMessageIDs table.
Please note the data storage class in the definition of the dout_toggle_message_t message data structure. This one is really important due to the way libcan call your can_receive_data_handler(). In fact, no data copy is made, and you get a direct pointer to the message receive buffer. Thus not putting a data storage class would make sdcc believe your pointer is general-purpose (21bit) pointer instead of a data memory (12 bit) pointer. Omitting it would lead to a PIC crash and restart!
You should process the message data before the return of can_receive_data_handler(). In fact, after that the receive buffer is freed and you would lose the data. If you want to copy the data to another part of the memory, you can use the can_helper_copy_data(…) provided by the library. (Note : this is nothing more than a reimplemented mem_copy()!)
void can_helper_copy_data(data_ptr from, data_ptr to, unsigned char length);
Detailed review of libcan
Local and global message IDs
ID conversion helpers
Message ID tables
Message ID binary decision tree
can_transmit_buffer_control type
howto/dev/libcan.txt · Last modified: 2007/12/20 16:21 by 127.0.0.1
