integrated_circuit
Integrated Circuit
Introduction
An Integrated Circuit is a formal name for a component commonly termed chip or IC, that is a small electronic device made out of a semiconductor material.
The first integrated circuit was developed in the 1950s by Jack Kilby of Texas Instruments and Robert Noyce of Fairchild Semiconductor, now a part of Schlumberger.
Integrated circuits are used for a variety of devices, including microprocessors (CPUs), audio and video equipment, and automobiles. Integrated circuits are often classified by the number of transistors and other electronic components they contain:
- SSI (small-scale integration): Up to 100 electronic components per chip
- MSI (medium-scale integration): From 100 to 3,000 electronic components per chip
- LSI (large-scale integration): From 3,000 to 100,000 electronic components per chip
- VLSI (very large-scale integration): From 100,000 to 1,000,000 electronic components per chip
- ULSI (ultra large-scale integration): More than 1 million electronic components per chip
IC are usually packaged in a plastic or ceramic case with external connector pins.
MIDIbox-related ICs
Description | Type | Mouser Ref | Reichelt ref | Digikey ref |
74HC165 | Serial Register | 595-CD74HC165EE4 | ||
74HC595 | Serial Register | 595-CD74HC595E | ||
74HCT541 | Line Driver | 595-D74HCT541E | ||
74HC00 | Logic Gate | 595-CD74HC00EE4 | ||
6N138 | OptoCoupler | 512-6N138M | ||
MOS4051 | Multiplexer switch | 595-CD74HC4051M96 | ||
TL072 | Operational Amplifier | 595-TL072ACP | ||
TL074 | Operational Amplifier | 512-LM324N | ||
MCP6004 | Operational Amplifier | 579-MCP6004-E/P | ||
MCP3208 | Analog>Digital converter | 579-MCP3208CIP | ||
MCP3428 | Analog>Digital converter | 579-MCP3428E/SL | ||
MAX525 | Digital>Analog converter | 700-MAX525BCPP | ||
CD22M3494EZ | Crosspoint switch | 968-CD22M3494EZ |
Datasheets
integrated_circuit.1465925259.txt.gz · Last modified: 2016/06/14 17:27 by psykhaze
