linux_mios32_toolchain_core
Core Toolchain Setup
  for MIOS32 application development on Linux
Preparation
This document assumes that you have a relatively modern x86 based linux distribution. While it may work other distributions, it has only been tested on x86 Ubuntu 10.10. Many of the commands, especially “aptitude” are only available on Debian derived distributions like Ubuntu.
Linux Utilities
subversion
You will need to install subversion to download the svn repository
  • sudo aptitude install subversion
wget
Wget is a useful tool for downloading files from the Internet and can be downloaded with:
  • sudo aptitude install wget
Required Stuff
Download the MIOS32 repository
Create a directory to download the toolchain to ( ~/midibox is my personal favourite). and download the repository:
  • mkdir ~/midibox
  • cd ~/midibox
  • svn checkout svnmios.midibox.org/mios32
(If that doesn't work try:)
* svn checkout svn://svnmios.midibox.org/mios32/
Linux build utilities
Terminal commands for installing basic build tools like “make”:
* Debian/Ubuntu/Mint: sudo aptitude install build-essential
* Arch Linux/Manjaro: sudo pacman -S base-devel
GNU Multiple Precision Library
Terminal Commands:
* Arch Linux/Manjaro: sudo pacman -S gmp
* Debian/Ubuntu/Mint: sudo aptitude install libgmp3-dev (or lib32gmp3-dev for AMD64Version)
Ubuntu, Mint troubleshoot: if it still doesnt build(make) it might be that you use a 64bit Computer, but the toolchain is for 32bit, so you will need additonal following commands:
sudo dpkg –add-architecture i386
sudo apt-get update
sudo apt-get install libc6:i386 libstdc++6:i386 zlib1g:i386
MIOS32 Toolchain
The MIDIbox community have created a modified GNU Compiler Collection, ready for use with the ARM Cortex M3 platform. The toolchain contains all of the tools required to build MIOS32 applications including GCC and NEWLIB.
The Toolchain has currently been compiled for Windows (2000+), Mac OS X (Leopard or newer) and Linux x86 (built on Ubuntu 10.10).
The download directory for the toolchain is http://www.midibox.org/mios32_toolchain
Download the latest “linux” file and extract into your favorite directory, If you extract into /usr/local the toolchain will create /usr/local/mios32_toolchain and various sub-directories containing the toolchain files.
replace xxxxxxx with the date of the latest linux toolchain in http://www.midibox.org/mios32_toolchain
You now need to set the path variable for the toolchain bin directory (/usr/local/mios32_toolchain/bin) this is covered in the next section
Environment Variables
If you are using the default bash shell then setting up path variables in the shell is quite easy, in a terminal window just type:
  • export VARIABLE_NAME=something
and if you want to check to what the variable has been assigned, type:
  • echo $VARIABLE_NAME
this will print what's inside the variable. For example, type:
  • export MIOS32_PATH=~/svn/mios32/trunk
to set up the mios32 folder path, then type
  • echo $MIOS32_PATH
Adding to the path
To temporarily add the mios32_toolchain bin directory to the path, type:
  • export PATH=$PATH:/usr/local/mios32_toolchain/bin
to check that the path variable has been assigned type:
  • echo $PATH
You should see the toolchain directory at the end of the path
Setup MIOS32 Environment
The following commands will setup the build environment for MIOS32, you must change MIOS32_PATH to be wherever you installed the svn repository:
  • export MIOS32_PATH=~/midibox/mios32/trunk
  • export MIOS32_BIN_PATH=$MIOS32_PATH/bin
  • export MIOS32_GCC_PREFIX=arm-none-eabi
  • export MIOS32_FAMILY=STM32F10x
  • export MIOS32_PROCESSOR=STM32F103RE
  • export MIOS32_BOARD=MBHP_CORE_STM32
  • export MIOS32_LCD=universal
You can add these lines to your ~/.profile file to ensure that they are always set, the editor pico (or nano) is a fairly simple text editor but you may have your favourite.
If you know what you are Doing in Linux-you can do this systemwide:
open your filebrowser with sudo rights, for example type in terminal:
* Linux Mint: sudo nemo
* Linux Arch: sudo thunar
the filebrowser now opens with root rights, navigate to the folder “etc” open the file “environment” »> /etc/environment
Depending on the path where your toolchain is situated, the Example Content off this file is:
  • PATH=“/home/autark/midibox/gcc-arm-none-eabi/bin”
  • MIOS32_PATH=/home/autark/midibox/mios32
  • MIOS32_BIN_PATH=/home/autark/midibox/mios32/bin
  • MIOS32_BOARD=MBHP_CORE_STM32F4
  • MIOS32_FAMILY=STM32F4xx
  • MIOS32_GCC_PREFIX=arm-none-eabi
  • MIOS32_PROCESSOR=STM32F407VG
  • MIOS32_LCD=universal
if you cant log after reboot, then mostly you messed up your “PATH” variable, in this case, boot with Linuxbootstick, and remove the PATH - line…
you can also add more folders to the PATH, they are separeted with a “:”, for example:
* PATH=“/home/autark/midibox/gcc-arm-none-eabi/bin:/home/autark/program”
here we also have a folder named “program”, when you put in there “Mios Studio”, then you can write in Terminal “Mios Studio” and mios studio will open
Building your first application
Once you have completed the above steps, you should be able to build your first application.
  • cd $MIOS32_PATH/apps/tutorials/001_forwarding_midi
  • make
if this works great! If not, either you made a mistake (or I did!!)
linux_mios32_toolchain_core.1716488944.txt.gz · Last modified: 2024/05/23 18:29 by phatline
