LRE8x2 096 SSD1306-BAR for Eurorack
I made this PCBs to use it with Fairlightii´s mb-lre8x2cs_pcb
4x PCBs on one 100x100mm
there is no V-Groove, you have to cut it on the marking
groove it on top and back, with a new sharp cutter, do it several times, then break it
With this Method you pay for 20 PCBs 8€ all inclusive to EU-Austria
So you can Stuff 5 LRE8x2 with this.
Here are the gerberfiles for production - i made it withJLCPCB
lre-oled-reva-gerber.zip
And they are working, they also V-Grooved on my marking without extra costs…
My next Revision would be a Micromatch header on the left side of the pcbs so i can directly interconnect to a Display Driver (crimping instead of soldering)
Hardware Requirements
- a MIOS32 Core to connect too
- LRE8x2 for its nature use
Shematic
Building and BOM
The Values are printet on the PCB.
Following Quantity is for 4 PCBs:
8x 1Row 7Pin headers (2.54mm pitch)
8x 1K 1208 SMD Resistors
12x 10uF 1208 Capacitors (non polarized)
3x 10K 0603 SMD Resistors which are optional
Frontpanel
I made a DXF File which you can send to Formulor in Germany
i panalized it so there are 2 Plates in it
I payed 40€ summed for booth plates incl shipping from Germany to Austria
2xlre-oled-bar-dxf.zip
Recommend Material from Formulor:
3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)
To Do
waiting for christmas…
Community users working on it
