LRE8x2 096 SSD1306-BAR for Eurorack V2
I made this PCBs to use it with Fairlightii´s mb-lre8x2cs_pcb
PCB
I didnt panalize it, so you have to do this when ordering the PCB online
you will need 4 PCBs per LRE8x2… normally you want to order 8 PCBs (using 2x LRE8x2)
Here are the gerberfiles for production - i made it withJLCPCB
lre-oled-bar2-gerber.zip
Hardware Requirements
- a MIOS32 Core to connect too
- DisplayDriver-SMD which buffers the Displays
- LRE8x2 for its nature use
- LRE5-LCD2 as UI to handle Patch management and automation (if you want to use my code…)
Shematic
Building and BOM
Following Quantity is for 1 PCB:
2x 1Row 7Pin Male headers (2.54mm pitch) - normally delivered with the Displays!
2x 8PIN Ribbon Connectors (2x4Pin Female) + Cables https://eu.mouser.com/ProductDetail/Wurth-Elektronik/61200823021?qs=PhR8RmCirEZvQm5v3EiYrA%3D%3D
2x 8PIN Ribbon Terminals (2x4Pin Male) SMD Variant https://jlcpcb.com/partdetail/boomele_boom_Precision_elec-C192300/C192300
8x 0.96“ SSD1306 Screens 7Pin Variant! i recommend white ones https://www.aliexpress.com/item/32638662748.html?spm=a2g0o.order_list.order_list_main.10.21ef1802NuwRWb
Frontpanel
I made a DXF File which you can send to Formulor in Germany
i panalized it so there are 2 Plates in it
I payed 40€ summed for booth plates incl shipping from Germany to Austria
Recommend Material from Formulor:
3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)
To Do
The LRE-OLED-Bar & The Frontpanel are a Part of my MSQ-CC-LRE-V2
so look there for more information….
Community users working on it
