ltc_module
LTC Module can be used to add Midi-thru port to Midibox, to Midi input/output activity LEDs or to connect Midibox to Computer RS232 port used as Midi a interface.
- LTC Module uCApps
- MIDIbox-to-COM uCApps
An easier way to connect to a COMM port would be to follow the “MIDIbox-to-COM” instructions, except using an RS232 Shifter Kit or the pre-assembled SMD version, RS232 Shifter SMD from SparkFun Electronics.
ltc_module.1197169386.txt.gz · Last modified: 2007/12/09 03:03 (external edit)
