midibox_ay_patch_menu
MIDIBox AY 3 8912 - PATCH MENU
Access the PATCH MENU via F1 (C64 Keyboard)
PATCH MENU Options:
- Store A Patch (Patch 0) to Eeprom (PIC 18F Eeprom, no Bankstick1 needed)
- Store A Patch (Patch 1 to 127) to Bankstick1 (BS)
- Format Bankstick1
The Patch Menu - Overview:
LCD ROW | Func. | Data | Memo |
1 | NAME: | PATCHNAME | Edit the Patchname here |
2 | NR : | 0 to 127 | Select the Patch Number here (Patch 0 = PIC internal Patch / 1 to 127 = Bankstick Patches) |
3 | DO : | L W F | Do Load Patch, Write Patch, Format Bankstick1 |
4 | status | (info) | (W: OK, L: OK, F: BS PATCH 1-127) |
Patch Menu - Editing:
LCD ROW | EDIT | KEYS |
1 | NAME | Use A-Z, 0-9, SPACE = “_”, after Patchname Editing the user can delete the Patchname via INST DEL key |
2 | Nr. | Use crsr ← → (+ / -) |
3 | Do | Use L W F |
Annotation:
- Bankstick (BS) = Bankstick1 by default
- Bankstick Formatting: Patch 1 to 127 will be written with the current Patch data (!). For instance: set the MIDI Channel Tone A to 8. Now every Bankstick Patch (1 -127) will have the MIDI Channel 8 (@Tone A) after Bankstick formatting (in this way it is easy to predefine a Patch Setup for all 127 Bankstick Patches).
- A “ ! ” before the [Patchname] (@LCD ROW1) indicates, that the Patch is NOT loaded yet.
- The Fx Data will be stored
- Patchname Cursor Pos. +1 = [CRSR →] or [+] or [>]
- Patchname Cursor Pos. -1 = [CRSR ←|(+SHIFT)] or [-] or [<]
- [INS DEL] or [CLR HOME] delete the patchname after patchname editing (this do not delete the patch data!).
midibox_ay_patch_menu.txt · Last modified: 2010/03/29 10:06 by lemonhorse
