midibox_seq_quick_reference
MB SEQ functions - quick reference
Detailed info for options and functions is available at http://www.ucapps.de/midibox_seq_manual_m.html
# Function Description / Options
Dedicated button functions (theese can vary depending on panel design and MBSEQ_HW.V4 file)
Pattern
1,2,3,4
Select pattern/track group - G1, G2, G3, G4
2
Track
1,2,3,4
Select track within track group - T1, T2, T3, T4. 16 tracks are available in total
3
Trigger layer
A,B,C
Select trigger layer A or B or C. Holding C opens trigger layer selection menu and allows to select others
<html>
Gate Acc Roll Glide Skip R.G(random gate) R.V(random value) No FX </html>
4
Parameter layer
A,B,C
Select parameter layer A and B. C switches between C & D or with Pressed&Hold open parameter layer selection menu and allows to select others.
Four parameter layers available by default, but CC, Pitch, Prob, Delay can be added via trigger selection menu (?) FIXME
<html>
Note Vel Length Roll </html>
5
Step View
View and select steps if more than 16 are used
<html>
1..16 17..32 …etc</html>
6
Pattern
Select/load pattern/track group G1, G2, G3, G4 from SD memory location
7
Song
Select song parameters
<html>
Song # Position Action{Stop; x1..x16; Jump Pos; Jump Song; Mixer; Tempo; Mutes} Select patterns G1,G2,G3,G4 </html>
8
Edit
Enter edit mode to edit parameter layer step values and set trigger layer steps
9
Mute
Quickly mute/unmute tracks 1…16
10
Solo
Solo current track
11
(Left/Right)
Move cursor position. Left has limited usage
12
(Inc/Dec)
Same as Jog Dial encoder - increases/decreases the current value
13
Exit
Quickly exit to top menu
14
Select
(Press&Hold) Select steps to be controlled by All function. Obviously has usage in other situations as well FIXME
15
All
Edit all selected steps set with Select function
16
Copy
Copy steps from selected # to #. Selection can be edited by Select function
17
Paste
Paste copied steps starting from # step. Selection can be edited by Select function
18
F1
(Clear)
(Press&Hold) Wipe selected track. Other functions can be assigned in MBSEQ_HW.V4 file
19
F2
(Select track)
(Press&Hold) Select track. Other functions can be assigned in MBSEQ_HW.V4 file
20
F3
(Select parameter layer)
(Press&Hold) Select parameter layer A,B,C,D…etc. Other functions can be assigned in MBSEQ_HW.V4 file
21
F4
(Select trigger layer)
(Press&Hold) Select/assigns trigger layer 1..8. Other functions can be assigned in MBSEQ_HW.V4 file
22
Rec
Open record menu
<html>
Track # Record{Live; Step} Mode{Mono; Poly} AStart{on; off} Step # TglGate Port # Chn # </html>
23
Rewind. Active only in song mode
24
Stop
Stop playback and reset position to beginning
25
Play
Start playback of patterns/song
26
Pause
Halt/resume playback
27
Forward. Active only in song mode
28
Metronome
Toggle metronome on/off
29
Fast
Activate Fast mode for quicker value selection with encoders. Speed options for Fast can be changed in MBSEQ_HW.V4 file
30
Scrub
(Press&Hold) + Jog Wheel dynamically change actual position
4 a b
midibox_seq_quick_reference.1273340762.txt.gz · Last modified: 2010/05/08 17:46 (external edit)
