midibox_seq_quick_reference
MB SEQ functions - quick reference
Detailed info for options and functions is available at http://www.ucapps.de/midibox_seq_manual_m.html
Print-friendly (on two A4 sheets) xls version available here mbseq_prn_.zip
# Function Description / Options
Dedicated button functions (these can vary depending on panel design and MBSEQ_HW.V4 file)
Pattern
1,2,3,4
Select pattern/track group - G1, G2, G3, G4
2
Track
1,2,3,4
Select track within track group - T1, T2, T3, T4. 16 tracks are available in total
3
Trigger layer
A,B,C
Select trigger layer A or B or C. Holding C opens trigger layer selection menu and allows to select others
<html>
Gate Acc Roll Glide Skip R.G(random gate) R.V(random value) No FX </html>
4
Parameter layer
A,B,C
Select parameter layer A and B. C switches between C & D or with Press&Hold open parameter layer selection menu and to select others.
Four parameter layers available by default, but CC, Pitch, Prob, Delay can be added via trigger selection menu (?) FIXME
<html>
Note Vel Length Roll </html>
5
Step View
View and select steps if more than 16 are used
<html>
1..16 17..32 …etc</html>
6
Pattern
Select/load pattern/track group G1, G2, G3, G4 from SD memory location
7
Song
Select song parameters
<html>
Song # Position Action{Stop; x1..x16; Jump Pos; Jump Song; Mixer; Tempo; Mutes} Select patterns: G1,G2,G3,G4 </html>
8
Edit
Enter edit mode to edit parameter layer step values and set trigger layer steps
9
Mute
Quickly mute/unmute tracks 1…16
10
Solo
Solo current track
11
(Left/Right)
Move cursor position. Left has limited usage
12
(Inc/Dec)
Same as Jog Dial encoder - increases/decreases the current value
13
Exit
Quickly exit to top (Session) menu.
<html>
(return to previous menu) Mute Tracks Open Save Save as New Info </html>
14
Select
(Press&Hold) Select steps to be controlled by All function. Select brings additional options in several other menus as well
15
All
Edit all selected steps set with Select function
16
Copy
Copy steps from selected # to #. Step # can be edited by Select function
17
Paste
Paste copied steps starting from # step. Step # can be edited by Select function
18
F1
(Clear)
(Press&Hold) Wipe selected track. Other functions can be assigned in MBSEQ_HW.V4 file
19
F2
(Select track)
(Press&Hold) Select track. Other functions can be assigned in MBSEQ_HW.V4 file
20
F3
(Select parameter layer)
(Press&Hold) Select parameter layer A,B,C,D…etc. Other functions can be assigned in MBSEQ_HW.V4 file
21
F4
(Select trigger layer)
(Press&Hold) Select/assign trigger layer 1..8. Other functions can be assigned in MBSEQ_HW.V4 file
22
Rec
Open record menu
<html>
Track # Record{Live; Step} Mode{Mono; Poly} AStart{on; off} Step # TglGate Port # Chn # </html>
23
Rewind. Active only in song mode
24
Stop
Stop playback and reset position to beginning
25
Play
Start playback of patterns/song
26
Pause
Halt/resume playback
27
Forward. Active only in song mode
28
Metronome
Toggle metronome on/off
29
Fast
Activate Fast mode for quicker value selection with encoders. Speed options for Fast can be changed in MBSEQ_HW.V4 file
30
Scrub
(Press&Hold) + Jog Wheel dynamically change actual position
Menu functions
31
Menu+Scrub
Toggle loop mode on/off
32
Menu+Metronome
External restart used to synchronize playback starting from next step
33
Menu+GP1
(Mixer)
Open mixer view for 16 tracks. 12 pages can be switched with +/-. An additional options available with Select button More details? FIXME
<html>
Midi port Midi channel Prog change Volume Panorama Reverb Chorus CC1 CC2 CC3 CC4 </html>
34
Menu+GP2
(Event)
Open track setup editor
<html>
Track # Type{Note; Chord; CC; Drum} Step # ParL # TrgL # Port # Chn # Edit Name </html>
35
Menu+GP3
(Mode)
Open track mode editor
<html>
Track # Track on/off Normal, Transpose, Arpeggiator </html>
<html>
Hold{on; off} | Sort{on; off} | Restart{on; off} | Scale{on; off} | Sustain{on; off} | </html> |
36
Menu+GP4
(Direction)
Open track playback direction editor
<html>
Track # Select playback mode: Forward, Backward, PingPong, Pendulum, Rand.Dir, Rand.Step, Rand.D+S </html>
<html>
Fwd # Back # Replay # Repeat # Skip # Itv # SyncM{yes; no} </html>
37
Menu+GP5
(Divider)
Open track clock divider setup editor
<html>
Track # Clock # Divider{normal; triplet} Sync to Measure{on; off} Timebase selector: 1, 2, 4, 8 ..etc </html>
38
Menu+GP6
(Length)
Open track length editor
<html>
Track # Length # Loop # Quick length selection: 4, 8, 16 ..etc </html>
39
Menu+GP7
(Transpose)
Open track transpose editor
<html>
Track # Transpose selector: -7 oct … +7 oct -7 sem … +7 sem </html>
40
Menu+GP8
(Groove)
Open track groove editor
<html>
Track # Groove style{off; shuffle … etc} Intensity # Step # Dly # Len # Vel # Num Steps # </html>
41
Menu+GP9
(Trigger)
Open track trigger layer selection menu
<html>
42
Menu+GP10
(FX)
Open FX editor
<html>
Local{Echo; Hum; Limit; LFO} Global{Loop; Scale} </html>
<html>   ·[Echo]
Track # Repeats # Delay # Vel.Lev # FB Velocity % Note # Gatelen % Tcks % </html>
<html>   ·[Hum]
Track # Intensity # Note{on; off} Vel/CC{on; off} Length{on; off} </html>
<html>   ·[Limit]
Track # Lower # Upper # </html>
<html>   ·[LFO]
Track # Wave{off; sine ..etc} Amp # Phs % Steps # Rst # OneShot{on; off} </html>
<html>
Note{on; off} Vel{on; off} Len{on; off} CC{on; off} ExtraCC # Offs # PPQN # </html>
<html>   ·[Loop]
Mode{all tracks / step view ..etc} Offset # Steps # Loop{on; off]} </html>
<html>   ·[Scale]
Control{global, G1, G2 ..etc} Root{Keyb, C …etc} Selected scale{major; minor …etc} </html>
43
Menu+GP11
(Manual trigger)
Manually trigger steps, (Press&Hold)+Select for sync to measure
<html>
</html> options? FIXME
44
Menu+GP12
(Morph)
Open track morphing setup
<html>
Track # Mode{on; off} Dst.Range # Value # Morphing control (also by CC1) </html>
45
Menu+GP13
(BPM)
Open BPM settings editor
<html>
Mode{Auto; Slave; Master} Preset # Tempo # Ramp sec. Fire Preset Preset Page </html>
<html>
MClk{USB1 ..etc} In{-,on} Out{-,on} Din PPQN # Ext.Restart Tap Tempo </html>
46
Menu+GP14
(Save)
Open save patterns/tracks menu
<html>
Group # Location # Target # Save Category Label </html>
47
Menu+GP15
(MIDI)
Opens midi setup editor
<html>  ·[Transpose and arp] Port #
Chn # T/A Split{on; off} Midd.Note # Reset Stcks</html>
<html>  ·[Section Control] Port #
Chn # G1 # G2 # G3 # G4 # Fwd port Reset Stcks</html>
<html>  ·[Midi Router] Node #
In port Chn # Out port Chn # Default Port</html>
<html>  ·[Misc] BLM_Scalar port{on; off}
Midi Monitor </html>
48
Menu+GP16
(SysEx)
SysEx operations Options? FIXME
Utility functions
49
Utility+GP1
(Track Select)
Select active track
50
Utility+GP2
(Copy)
51
Utility+GP3
(Paste)
52
Utility+GP4
(Clear)
Wipe the track. No options - Wipes the track instantly!!!
53
Utility+GP5
(Move)
Move selected steps (like copy and paste together)
54
Utility+GP6
(Scroll)
Scroll the steps across
55
Utility+GP7
(Random)
Generates random events
<html>
Track # Generate Clr Util Undo LayerA # LayerB # LayerC # TrgA # Trg B # Trg C # </html>
56
Utility+GP8
(Undo)
Undo last Paste, Clear, Move, Scroll, Random operation
57
Utility+GP9
(Save)
Open save menu
<html>
58
Utility+GP10
(Record)
Open record menu
<html>
59
Utility+GP11
(Mixer)
<html>
60
Utility+GP12
(Options)
Open options menu
<html>
Measure # Pattern # SyncChange (on, off) Paste/Clr steps </html>
<html>
Remote{auto;client;server} ID # Port # Request connection{no} </html>
61
Utility+GP13
(Port Mute)
Access output port muting menu
<html>
Def USB1 USB2 …etc… AOUT Bus1 Bus2 </html>
62
Utility+GP14
(Disk)
Open disk menu
<html>  MSD USB{disabled; enabled/Pres&Hold/}
Midi files{import; export; play} </html>
63
Utility+GP15
(Mute)
Quick mute of all tracks/channels
64
Utility+GP16
(Unmute)
Quick unmute of all tracks/channels
To do:
  • check descriptions and options for all functions in this quick reference
  • fix/complement all “fixme” issues
  • add highlight and fontcolor [http://www.dokuwiki.org/plugin:fontcolor] plugins so that font/background color of the options can be changed
midibox_seq_quick_reference.txt · Last modified: 2010/05/18 16:45 by gjvti
