opl3_module_modified
MBHP_OPL3 module modifications, the 5V option
The OPL3 module originally has three TL074 op-amps, and a circuit that needs +/-12V bipolar power supply.
In Wilba and nILS sammichFM, they use two OPA4348 rail-to-rail op-amps, that can be powered by 5V.
Sauraen suggested another 5V rail-to rail op-amp, the MCP6004, which is pin compatible with the TL074, and a way to modify the OPL3 module to use these.
- Replace R5,R7,R10 and R13 with jumpers
- Bridge IC6 pads 1&3, 5&7, 8&10 and 12&14
- Leave out:
IC6
R4, R6, R8, R9, R11, R12, R14, R15
C15, C16, C19, C20, C23-C30
- Bridge C20 pads (to supply Ground for the op-amps)
- Leave out bridges to IC6
- Use MCP6004 for IC3 and IC5
opl3_module_modified.1390902651.txt.gz · Last modified: 2014/01/28 09:50 by eptheca
