sensors
Sensors
Introduction
Here you'll find plenty of informations about various sensor-types and how to connect them to a midibox. If you're interested in working with sensors, you might also want to check out the ACSensorizer-Midibox project.
Keep in mind that most of sensors are analog , so they require some AINSER Module to be plugged as inputs to the Core Board.
Sensor-Wiki maintains a free list of possible sensors you could experiment with . For example the picture above is a EEG Active Electrode from the OpenEEG Project. A mind-controlled midibox ? who said that ?
Forum Topics
: Correct Forum links
- How to connect Non-10k Resistance-based Sensors: http://www.midibox.org/forum/index.php?topic=6506.0
- What's the issue about linearity? http://www.midibox.org/forum/index.php?topic=6728.0
- About Distance Sensors: http://www.midibox.org/forum/index.php?topic=5270.0
- About TouchPads, SoftPots and other interesting stuff: http://www.midibox.org/forum/index.php?topic=5023.0
- Touch Sensors (as Buttons): http://www.midibox.org/forum/index.php?topic=9220.0
- How to connect Flex-Sensors: http://www.midibox.org/forum/index.php?topic=5388.0
- Accelerometers, Tilt-Sensors: http://www.midibox.org/forum/index.php?topic=1985.0
- About Ribbon-Controllers: http://www.midibox.org/forum/index.php?topic=9679.0
sensors.1465323039.txt.gz · Last modified: 2016/06/07 18:10 by psykhaze
