SRIO-ROUTER
* Route 1 Userinterface to 8 Cores
* So you save space in your Eurorack
* So you save money
* Route SRIO (J89 aka DIN and DOUT)
* ROUTE 8x OLED Screens
* No Support for AIN
ready for Pick and Place
–all Parts are presoldered except:
- 2x Switches
- 8x LEDs
- Micromatch Headers
Hardware Requirements
- up to 8 CV1 or other MIOS32 Cores
- dont forget the Micromatch connectors, and Ribbon cables
Shematic
Building
The Design is optimized for Pick and Place > all SMD Parts are on the Top-PCB
The Rest is Thruhole > easy handsolder
now waiting for Presoldered PCBs
BOM
these are the parts which must be handsoldered
14-24x Micromatch Header 2x5p:
Mouser: 571-12150790
Reichelt: MPE 369-1-010
LCSC: C590954
14-24 Micromatch Plug 2x5p or even more…:
Mouser: 571-1-2178712-0
Reichelt: MPE 372-1-010
2x Tact Switch:
Mouser: 113-DTSA-65N-V
Reichelt: TASTER 3305B
8x 3mm LED Thruhole ca 400mcd:
Mouser: 859-LTL1CHJETNN
Reichelt: EVL 1224-10SURC
Flat-band-Cable - 30m !!! x 40pins…last forever:
617-09180407001
BOM LCSC
these are the parts which are presoldered by the Pick and Place Machine
| Comment | Designator | Footprint | LCSC Part Number |
| 47uF | C1,C2 | 1206 | C96123 |
| 100nF | C3,C4,C7,C8 | 0805 | C49678 |
| 10uF | C5,C6 | 1206 | C13585 |
| LED-Yellow | Da1,Db1,Dc1,Dd1,De1-Da19,Db19,Dc19,Dd19,De19 | 0603 | C72038 |
| 180 | R1-R5 | 0603 | C22828 |
| 1K | R6,R7 | 1206 | C4410 |
| 10k | R8-R25 | 0603 | C25804 |
| 74HC595 | U1-U3 | SOIC-16 | C5947 |
| 74HC165 | U4,U5 | SOIC-16 | C5613 |
+ Ribbon Cables for example (MOUSER):
710-63911015521CAB|1
PART Locations
To Do
Community users working on it
