STELLAx4
4x 8Bit Soundchips/TIAś on a 10x10cm PCB,
controlled from a STM32F4 Microcontroller dipcoref4,
based on Antichambreś TIA Module, with AD9833ś as External programmable Clock, the Frequency-range is expandet…
The Board acts a Motherboard, for
- 4x Soundchip… AND:
also like the stm32f4_module it provides:
- Midi-IO - 1x IN, 1x OUT > 3,5Jacks/TRS
- µSD-Card - 2 Save Patches
- J19>AoutNG - to connect VCF or VCAs…
- J15 (JLCD1) which handle from Stock 4x SPI-Displays (SSD1306), - 4 the UI
- J1>chain a nother STELLAx4 as “SLAVE” to it, to expand polyphony
ready for Pick and Place
–all SMD-Parts are on one SIDE and are presoldered..
Features
* Summed or Individual Audio-Outs, selectable via normal Jumpers
* NTSC or PAL > select via SMD-Solder-Jumper
* User-Interface is C-Language-Programmable
Hardware Requirements
- 4 x TIA/STELLA [PAL or NTSC…)
- 5V from Mini-USB-Plug, or 5V at a 2Pin-Header connected to example a Eurorack Power Source (+5VDC!)
- dont forget Midi TRS Cables
Shematic
Rev.A
stellax4-shematic.pdf
Rev.B
stellax4-shematic-b.pdf
Building
The Design is optimized for Pick and Place > all SMD Parts are on the Top-PCB
The Rest is Thruhole > easy
BOM LCSC
these are the parts which are presoldered by the Pick and Place Machine
Comment | Designator | Footprint | LCSC Part Number |
100nF | Ca1,Cb1,Cc1,Cs1,Cd1,Ca2,Cb2,Cc2,C2,Cd2,Ca3,Cb3,Cc3,Cp3,Cpa3,Cd3,Ca4,Cb4,Cc4,Cd4,Cu4,Ca5,Cb5,Cc5,Cd5,Ca6,Cb6,Cc6,Cd6 | 0805 | C49678 |
47uF | Cp1,Cpa1,Cp2,Cpa2,Ca7,Cb7,Cc7,Cd7 | 1206 | C96123 |
10uF | Ca8,Cb8,Cc8,Cd8 | 1206 | C13585 |
1N4148W | D1 | SOD123 | C81598 |
74HC2G32 | IC1,IC2,IC3,IC4 | VSSOP-8_2.3x2mm_P0.5mm | C91874 |
AD9833BRMZ | NCO1,NCO2,NCO3,NCO4 | MSOP-10_3x3mm_P0.5mm | C9652 |
Oscillator | OSC1 | 25×20-4Pole-SMD | C90621 |
220 | R1,R2,R3 | 1206 | C17958 |
4K7 | R4 | 1206 | C17936 |
1K | R5 | 1206 | C4410 |
1K8 | Ra1,Rb1,Rc1,Rd1,Ra2,Rb2,Rc2,Rd2 | 0805 | C17398 |
100K | “Ra3,Rb3,Rc3,Rd3,Ra4,Rb4,Rc4,Rd4” | 0805 | C17407 |
74HC595 | Sa1,Sb1,Sc1,Sd1,S1,Sa2,Sb2,Sc2,Sd2 | SOIC-16 | C5947 |
74HC541-TSSOP | U4 | TSSOP20 | C406865 |
BOM Mouser
30,39€ exlc shipping > so better order other stuff too, over 50€ there is free shipping!
Parts for Handsolder:copy list below, and paste in this link
647-UFG1H100MDM|8
649-68000-220HLF|3
151-8010-E|10
571-1-2178710-0|4
490-SJ1-3535NG|3
575-1104764041001000|4
200-CES12001TS|3
512-6N138M|1
575-1104730841001000|1
798-DM3AT-SF-PEJM5|1
474-COM-15107|1
for prototyping i ordered:
490-SJ1-3535NG-GR instead of 490-SJ1-3535NG because it is out of stock - so GREEN sockets for now!
Cable-Connectors for UserInterface and AOUT-Module you will need also:
571-1-2178712-0|8
+ Ribbon Cables for example:
710-63911015521CAB|1
Comment | Designator | Mouser Part Nr |
Header-1×3 | AUDIO1,SUMMED1,AUDIO2,AUDIO3,AUDIO4 | Includet in „Header 1×2“ |
10uF-Audio | Ca9,Cb9,Cc9,Cd9,Ca10,Cb10,Cc10,Cd10 | 647-UFG1H100MDM |
Header-1×2-JUMPER / HEADER | GND1,Rail1,SumA1,SumC1,SumD1,SumA2,SumC2,SumD2,SumB2,JBOOT1,AIN1,PSU1,J18 | 649-68000-220HLF |
Header-1×2-JUMPER | GND1,Rail1,SumA1,SumC1,SumD1,SumA2,SumC2,SumD2,SumB2 | 151-8010-E |
Header-2×5-Micromatch | JLCD1,J1,J19,J89 | 571-1-2178710-0 |
3.5Jack | Midi-I-1,Midi-O-1 | 490-SJ1-3535NG |
TIA | TIA1,TIA2,TIA3,TIA4 | 575-1104764041001000 |
Socket for DIPCOREF4_52P | U1 | 200-CES12001TS |
6N138 | U2 | 512-6N138M |
Socket for 6N138 | U2 | 575-1104730841001000 |
uSD_DM3ATDM3AT | U3 | 798-DM3AT-SF-PEJM5 |
uSD CARD | sparkfun 1GB | 474-COM-15107 |
PART Locations
To Do
waiting for christmas
UI-PCBs
Debugging First Version
Community users working on it
- antichambre = Shematic, Porting 8>32Bit, Programming…
Community users interested on it
- sajtron = Chip composer who maybe wanna buy one…
