tk_gm5_bulkorder
Request List for the 6th bulk order of “GM5” - this is an Atmel AVR based USB chip with preburned USB-MIDI firmware (out-of-the-box solution)
This product has been developed by http://www.ploytec.de
Schematics and Eagle file of the PCB: http://www.ucapps.de/mbhp_usb_gm5.html
The chip works under Windows/MacOS/Linux with the common USB-MIDI-Driver, but there is also a custom driver for Windows available to overcome the Microsoft driver flaws (a drawback of the old MBHP_USB module)
Per chip you will get 5 physical MIDI IOs. The dedicated Windows driver makes it multi-client capable. Under MacOS the interface is multi-client capable by default.
Package: TQFP32 (SMD, but can be soldered with a good soldering iron similar to AN2131SC (→ MBHP_USB))
Prices (inclusive 19% VAT):
4.50 EUR per unit for a batch of 250 chips
3.50 EUR per unit for a batch of 1000 chips
Minimum quantity: n x 250
First come, first serve! We need n x 250 chips, if more than 250, but less than 500 chips are preordered, you need to wait for the next run
Beside of the GM5 chips, Ploytec also provides PCBs especially made for midibox.org for 3.00 EUR pp. (incl. 19% VAT)
Please specify the desired quantity at the third column.
History:
Bulk OrderGM5 QuantityPCB Quantity
1st500400
2nd25095
3rd250105
4th250100
5th2500
—IN STOCK—remaining chips are reservednone (!)
Unfortunately it's very unlikely that a new bulk order will happen…
…but wait: if everybody would order at least 4 GM5 chips, we only need ca. 62 people!
So, let's check if we reach 250 pieces again for the 6th bulk order:
UsernameGM5 QuantityMiniPCB QuantityGM5x5x5PCB Quantity
Dummy 4 4 0
rosch413
jojjelito 10 0 6
moogah 4 4 2
funkyboard 8 2 0
mazatta402
schrabikus440
technobreath604
elektruck413
Altitude403
min struct1024
gslug853
skwosh606
phaphane402
tosol202
filter303606
Fizzen 420
lindeborg403
Stiebz403
Fos422
ckoester422
rvlt440
Gilesjuk404
DaveyM69411
ADK202
romsom10010
stobiepole550
Sampas211
digga10010
Triffki853
Ripper431
thebot404
ranger930550
nebula400
Lanu64x220
Zossen101
MaG2k422
ghost_danser532
PeterK1240
woluf02020
shimoda733
loderbast523
qp504
mburch404
Fresh Pants422
MicMicMan413
V`cent413
midisizer422
fcd72706
tb323404
nicore404
DrKorg202
Ermangaver101
Antix212
Arkay101
Norbim1220
Moduku220
—TOTAL— 262 82 141
tk_gm5_bulkorder.1347628706.txt.gz · Last modified: 2012/09/14 13:18 by moduku
