tm5-dindoutgate
TM5-DinDoutGates
this is one essential part for my triggermatrix5
it gives 24 Digital Inputs, and 32 Digital Outputs, while 16 Outputs are used for UI, the othere 16 are buffered, and are for use as 16 GAte/Triggger output at 5V Level
i created this board. its fully SMD, and made it pick and place ready - so no soldering required!
Shematic
Building and BOM
Its build by pick and place robots… so no need to build
BOM
| qty | reference | value | footprint | jlc |
| 18 | C1 – C12, Ca3, Ca4, Ca5, Cb3, Cb4, Cb5, Cb6 | 100n | C_0402 | C307331 |
| 5 | C9, Ca1, Ca2, Cb1, Cb2 | 10uF | C0805 | C440198 |
| 5 | DIN1, DIN2, DIN3, Gate1, Gate2 | Gates | Pin-Head-10-SMD | C124391 |
| 4 | DOUT1, DOUT2, Jin8/1, Jout8/9 | DIN/DOUT | Pin-Head-10-SMD | C124391 |
| 4 | IC1, IC2, IC3, IC4 | 74HC595-bigger | HC595-smd | C5947 |
| 3 | IC5, IC6, IC7 | 74HC165-bigger | HC165-smd | C5613 |
| 1 | LED1 | LED | LED-0603 | C2286 |
| 16 | Q1 – Q16 | MMBT3904-7-F | MMBT3904-7-F | C20526 |
| 16 | R1 – R16 | 220 | R_0805 | C25294 |
| 42 | R17 – R74 | 10K | R_0402 | C25744 |
| 16 | R33 – R48 | 10K | R_1206 | C17902 |
| 2 | R75, R76 | 220 | R_0402 | C25091 |
To Do
waiting for the assembled Prototype
Community users working on it
tm5-dindoutgate.1672064657.txt.gz · Last modified: 2022/12/26 14:24 by phatline
