tracing_unknown_lcd_pinout
IF Your display is a HD44780 compatible, but has no datasheet available: You can try *tracing* the connector pinout by using HD44780 datasheet as a reference.
All pins of the connector expect V0 1), possible Vee 2) and possible Backlight power pins 3) are directly connected to the HD44780 controller 4).
If You have the basic electronics knowledge:
You should be able to trace LCD pinout by watching the controller pin arrangement and using conductivity tester of your Multimeter.
tracing_unknown_lcd_pinout.1143631853.txt.gz ยท Last modified: 2006/10/15 09:35 (external edit)
