MIDIbox Wiki Instructions
Wiki Syntax
The best way to learn the syntax and how it is used in the midibox-wiki is just to study existing pages. The syntax is easy to read and learn.
Follow this link to learn more about the syntax.
About Namespaces
All wiki-pages are organized in namespaces. A namespace works excatly like a folder, ':' is used as a separator, links can be absolute or relative to the current namespace:
'[[:home | Home]]' links to the page 'home' in the root namespace '[[.:mbhp:module:din | DIN digital inputs]]' links to the page 'mbhp:module:din' in the current namespace '[[din_dout_pin_list | DIN & DOUT pin table]]' links to the page 'din_dout_pin_list' in the current namespace The text before the '|' is the page to link to, the one after it is the linked text. note that 'mbhp:module:din' would **not** be relative to the current namespace. It would be equivalent to ':mbhp:module:din'
If you want to read more about DokuWiki-namespaces, follow this link.
Note that if you are on the page ':home:mbhp', you are in the namespace 'home', not 'home:mbhp'. This is a bit confusing, because there is on one hand a page called 'mbhp', on the other there is a namespace called 'mbhp' (:home:mbhp), for example 'home:mbhp:module:din'. To link from the page ':home:mbhp' to ':home:mbhp:module:din' relatively, you would use '.:mbhp:module:din'. Of course you could also use the absolute link ':home:mbhp:module:din'.
However, in most cases it will be easier and safer to just use absolute links.
Namespace Map
This is the namespace-structure of the midibox-wiki. All information concerning the midibox-project has to be somwhere in the 'home' namespace, the 'wikify' namespace is the place for information about how to edit/update the midibox-wiki.
- home
- about
- faq
- skills
- project
- controller
- project name if required
- sequencer
- synthesizer
- misc
- mbhp
- module
- pic
- stm32
- mios
- mios32
- troubleshooting
- svn
- community
- bulk_order
- wikify
- template
Global Documentation
Homepage template, with templates for child pages, as per the above namespace map.
