  • entries
    6
  • comments
    16
  • views
    25,925
MB-TIA Cartridge. Max Manager Software and Drum Kit Sound Demo.
Antichambre
Firmware is working.
Manager is ready.
Features:
  • 2 dedicated envelopes with optional non-linear curve for each voice, which can be assigned to Pitch and Volume
  • 2 additional envelopes with optional non-linear curve which can be assigned to Pitch and Volume
  • 4 additional LFOs with different waveforms which can be assigned to Pitch and Volume
  • Pitch Bender
  • Portamento with optional "Constant Time Glide" function
  • Delays
  • Arpeggiator
  • Poly, Mono, Multi and Legato Mode
  • Separate keyboard zones for each voice (key splitting) allows to play voices separately
  • Free controller assignments to Modulation Velocity AUD0, Velocity AUD1, Wheel and Aftertouch
  • Wave and CC sequences which allow more percussive sounds
  • 2 Wavetables, 3 modes (Single 1x32, double 2x16 and Kit)
  • In Kit Mode Wavetable is used as Key mapping table
  • The wavetable sequencer can be combined with the arpeggiator in order to realize complex textures
  • LFOs, Envelopes, Wavetables, Arpeggios optionally syncable via external MIDI clock
  • OS independent MaxMsp Manager
  • BankStick support (128 sound patches per stick, up to 2 are internally connected)
MaxMsp Manager:
blogentry-7584-0-72669300-1314287842_thu
Here preset(patch) is 'Drum Kit 1'
- Voice Mode : Poly, max 2 notes at a time.
- Wavetable Mode : Kit, one note / one sound.
'Drum Kit 1' Sound demo:
Only one MIDI track, five differents sounds, for this drum pattern.
The track starts with this five sounds.
Next part: MB-TIA Cartridge. Final PCB.
5 Comments
I will propose a batch quickly, I hope in october, thank you for your interest, your can find some photos of prototype in my album...
I wasn't aware of little-scale's work, thank you, is it your work? What's the A26F interface? Does it work with synthcard?
Maybe You Can help me. I am looking for someone who has already identified sounds and their codes (AUDF / AUDC), to complete Patchs and Banks.
I'm looking for a typical melody for box startup, a MIDI file + code(AUDF/AUDC) for each note used in sequence, length from 1 to 3s.
I've got a lot of work this time,
thx for your interest.
PCB which fits in cartridge is drawn but i need time for print one and test it before propose a batch.
Stay in tune...
For the chips, all mines are from cannibalized 2600 ;)
