Hello Peter,
thank you for your help, i was hoping that you reply to my post.
So i stumbled upon your older post before and tried to understand what you did, but i could not find the lines of code that you changed!
Befor i get to changes on the display, i need to sort out the problem with compiling from the original source code.
I dont know why the frontpanel is not working after i recompiling from source. Do i make some changes elswhere to get that working?
The core is STM32F4 with wilba frontpanel configuration.
And yes the V4+ is intriguing, but i chose the V4 before.
I understand this as a longer term project so i have no rush, meanwhile i took some standard display to finish the build and start using that seq.
Thanks and kindest regards
Carsten
