folly
65 -
Everything posted by folly
Hi FANTOM XR or abandoned MIDIBOX Kb.It did not fit with the software Varranger.
hi all! I built MBP CORE STM32F4. everything works except Aiser 64 and 8. We are sure that, S1 of J19 connects to pin PB4 of MBHP_CORE_STM32F4? thank.
hi! I found eror while drawing the pcb.
I need to 4 potentiometers for volume track.
I'm already eroding the pcb. thank you !
I still use lpc1769. I bought STM32F4 and wanted to know if the problem of jiter and resolved. I would not build the PCB and then again have problems with jitter. if you tell me that and ok, I build the pcb.
HI! that the project ARDUINO used?
hi! STM32F4 DISCOVERY with it and solved the problem of jitter (potentiometers)? best regards.
THANK YOU TK!! I try then I tell you. with a single button I can change bank 1 and bank 2?
Hi all! You can use 8 encoder for 16 midi tracks? change the function with a switch? thank!
I have not yet solved the problems with jitter even though I tried with ainser64. with STM32F DISCOVERY you solve this problem?
I run this setup default.ngc and everything works great ..(encoder ALPS 24 pp- detent). thanks Thorsten. ENC n= 4 sr= 9 pins=6:7 type=detented3 EVENT_ENC id=4 hw_id=4 enc_mode=Inc01_Dec7F if_equal=0x01 type=CC cc=96 lcd_pos=1:1:2 label="Enc INC" EVENT_ENC id=4 hw_id=4 enc_mode=Inc01_Dec7F if_equal=0x7f type=CC cc=97 lcd_pos=1:1:2 label="Enc DEC" Best Regards
THANK YOU THORSTEN! Then do the tests then tell you how it goes. Regards, Silviu.
Thak Thorsen!!
there is no one who understands my problem? :sad: :question:
I WANT set to an encoder, 2 control change EXAMPLE; turning left CC = 1; turning to the right CC = 2 how you doing? thank!
Hello Thorsen! Hello everyone! After a year of family problems I returned to my hoby. Last year I finished my master keyb 76 keys. Now I'm trying midio128 v3 with lpc1769, about 110 buttons and 20 fader that works very well. I need CONNECTING also 2 encoder on dinx4. there any posibility? thank! Silviu
Thanks TK. now I can start drawing my keyboard.
hello to everyone! does anyone know how you enable the MIDI IN 1 - 2 of MIDIBOXKB? I do routing between MIDI IN 1 to 2 MIDIOUT. I want to connect midibox64, with 20 potentiometers
HI Solved the problem of parasites with Ainser64? thank!
I thank you all in two, and also Duggle, because the problems I found with him. Now I'm happy. Thank you so much
Hello Duggle! I did not write in forums vArranger because as I wrote above I tried u other hosts (livestyler). the problem is the same as vArranger. What do I do? I write to all of them? do you think you bring them to change their software for me?
hello kpete! thanks for your help. I am not able to compile because I have never been able to download the source files. and do not even know which software is compiled. I'm not a programmer. thank!
Hello Duggle! I have not written to varranger because I tried it with another host (LIVESTYLER). even with this we have the problem. Please TK to do some modification of software MIIDIBOX KB?
Hi kpete. Then we must pray to the creator of midibox kb that solves this problem if possible.
