So my midibox is mostly happy, led issues sorted out, aout perfectly calibrated, BLM and TPD doing what they should, but the TPD has a problem I think may be setup related.
First up, the 4 buttons only light up at startup, and most importantly the Doutx4 after do nothing. So hardware wise that would indicate the serial chain not passing through somehow. Ive checked U5 and U9, the led matrix works as far as I can tell (two colours, counting up, and showing note on on channel) so the serial must pass through it, and U9 has been very carefully checked and changed for certainty, but neither leds light up, nor does Doutx4 work. It should not be a parts or soldering error, so pointing at setup/software. Wire might be a bit long internally, but it seems to stop at U9 anyhow.
Anyone encountered something similar? Is there any setting in the v4 itself I should check? For channel or main setup/options?
I first used my own HW file, then changed to beautyofdecays file as I basically stole his setup and I thought that might fix it.
His inserted below:
# Setup File for Wilba's Frontpanel
# $Id: MBSEQ_HW.V4 2502 2017-06-10 21:15:17Z tk $
# MIDI Remote Keyboard Function
# The note number which activates the remote function
# 96 = C-6 (some MIDI monitors display C-5)
# 0 disables the remote keyboard function
MIDI_REMOTE_KEY 96
# The CC number which activates the remote function
# (e.g. to control it with a footswitch)
# Allowed numbers: 1-127 for CC#1..CC#127
# 0 disables the function (default)
MIDI_REMOTE_CC 0
# Track Selection CC
# Allows to synchronize track selections with a DAW
# select the mode:
# 0: no CC sent on track changes
# 1: send a single CC which contains the track number as value
# 2: send CC..CC+15 depending on track number with value 127
TRACK_CC_MODE 0
# over which port should the CC be sent?
# specifiy: USB1..USB4, OUT1..OUT4, IIC1..IIC4, AOUT (haha ;-), OSC1..OSC4
TRACK_CC_PORT USB1
# over which MIDI channel should the CC be sent (1..16)?
TRACK_CC_CHANNEL 1
# which CC number should be sent (if TRACK_CC_MODE == 2: the first CC)
TRACK_CC_NUMBER 100
# Running status optimisation
# Enabled by default, should be disabled if a MIDI
# device connected to a MIDI port doesn't fully
# comply to the MIDI specification.
# Expects two parameters: port number and 0/1 to
# disable/enable the optimisation.
# OUT1 (MIDI1 port of MBHP_CORE_STM32 and MBHP_CORE_LPC17 module)
RS_OPTIMISATION OUT1 1
# OUT2 (MIDI2 port of MBHP_CORE_STM32 and MBHP_CORE_LPC17 module)
RS_OPTIMISATION OUT2 1
# OUT3 (MIDI3 port of MBHP_CORE_STM32 and MBHP_CORE_LPC17 module)
RS_OPTIMISATION OUT3 1
# OUT4 (MIDI4 port of MBHP_CORE_LPC17 module)
RS_OPTIMISATION OUT4 1
# Menu Shortcuts allow a quick selection of menu pages.
# Will be displayed when the "MENU" button is pressed
# Syntax: MENU_SHORTCUT <gp-button-number> <page-name>
# <gp-button-number> in the range of 1..16
# <page-name>: one of these names:
# - MENU (Page Menu)
# - FXSEL (Fx Selection)
# - STEPSEL (Step Selection)
# - TRGSEL (Trigger Selection)
# - PARSEL (Param. Selection)
# - TRACKSEL (Track Selection)
# - BPM_PRESETS (BPM Presets)
# - EDIT (Edit)
# - MUTE (Mute Tracks)
# - MUTE_PORTS (Mute Ports)
# - PATTERNS (Patterns)
# - SONG (Song)
# - MIXER (Mixer)
# - EVENTS (Track Events)
# - MODE (Track Mode)
# - DIRECTION (Track Direction)
# - DIVIDER (Track ClockDivider)
# - LENGTH (Track Length)
# - TRANSPOSE (Track Transpose)
# - GROOVE (Track Groove)
# - TRG_ASSIGN (Track Triggers)
# - MORPH (Track Morphing)
# - RANDOM (Random Generator)
# - EUCLID (Track Euclid Generator)
# - RECORD (Record)
# - MANUAL (Manual Trigger)
# - FX_ECHO (Track Fx: Echo)
# - FX_HUMANIZER (Track Fx: Humanize)
# - FX_LIMIT (Track Fx: Limit)
# - FX_LFO (Track Fx: LFO)
# - FX_DUPLICATE (Track Fx: Duplicate)
# - FX_LOOP (Global Fx: Loop)
# - FX_SCALE (Global Fx: Scale)
# - UTIL (Utilities)
# - BPM (BPM Selection)
# - OPTIONS (Options)
# - SAVE (Save Pattern)
# - METRONOME (Metronome)
# - MIDI (MIDI Configuration)
# - MIDIMON (MIDI Monitor)
# - SYSEX (SysEx)
# - CVCFG (CV Configuration)
# - DISK (Disk (SD Card))
# - ETH_OSC (Ethernet & OSC)
# - LIVE (Live Play)
# - REMIX (Pattern Remix)
# - BOOKMARKS (Bookmarks)
# - ABOUT (About this MIDIbox)
MENU_SHORTCUT 1 MIXER
MENU_SHORTCUT 2 EVENTS
MENU_SHORTCUT 3 MODE
MENU_SHORTCUT 4 DIRECTION
MENU_SHORTCUT 5 DIVIDER
MENU_SHORTCUT 6 LENGTH
MENU_SHORTCUT 7 TRANSPOSE
MENU_SHORTCUT 8 GROOVE
MENU_SHORTCUT 9 TRG_ASSIGN
MENU_SHORTCUT 10 FXSEL
MENU_SHORTCUT 11 MANUAL
MENU_SHORTCUT 12 MORPH
MENU_SHORTCUT 13 BPM
MENU_SHORTCUT 14 SAVE
MENU_SHORTCUT 15 MIDI
MENU_SHORTCUT 16 SYSEX
# Shift Register Setup
# maximum number of connected shift registers in a DIN or DOUT chain (1..23)
SRIO_NUM_SR 23
# number of first and second DOUT shift register used for GP LEDs
GP_DOUT_L_SR 0
GP_DOUT_R_SR 0
# DOUTs for Dual Color option:
GP_DOUT_L2_SR 0
GP_DOUT_R2_SR 0
# OPTIONAL: individual track LEDs can optionally be assigned to SRs:
# they correspond with the BUTTON_DIRECT_TRACK* buttons
TRACKS_DOUT_L_SR 0
TRACKS_DOUT_R_SR 0
# sets the debounce delay for low-quality buttons in mS
# use low values for high quality buttons - this ensures best latency.
# use higher values for lower quality buttons.
# Recommended values:
# - 0 for high quality buttons (we used it many months w/o complaints)
# - 5 is the default
# - 20 for low-quality buttons
DEBOUNCE_DELAY 5
# Optional BLM Matrix
# set this value to 1 if each track has its own set of 16 LEDs to display unmuted steps and current sequencer position
# or if you are using a button/led matrix for misc. button/LED functions
BLM_ENABLED 1
# define the shift registers to which the anodes of these LEDs are connected
# Note: they can be equal to GP_DOUT_[LH]_SR, this saves two shift registers, but doesn't allow a separate view of UI selections
BLM_DOUT_L1_SR 4
BLM_DOUT_R1_SR 7
# define the shift register to which the cathodes of these LEDs are connected
# Note that the whole shift register (8 pins) will be allocated! The 4 select lines are duplicated (4 for LED matrix, 4 for button matrix)
# The second DOUT_CATHODES2 selection is optional if LEDs with high power consumption are used - set this to 0 if not used
BLM_DOUT_CATHODES_SR1 3
BLM_DOUT_CATHODES_SR2 6
# set an inversion mask for the DOUT shift registers if sink drivers (transistors)
# have been added to the cathode lines
# Settings: 0x00 - no sink drivers
# 0xf0 - sink drivers connected to D0..D3
# 0x0f - sink drivers connected to D7..D4
BLM_DOUT_CATHODES_INV_MASK 0x00
# 0: no DUO colour LEDs are connected to the LED matrix (position marker inverts step LED)
# 1: DUO colour LEDs are connected to the LED matrix, second LED displays position marker
# 2: Like option 1, but the first LED is turned off when the position marker activates the second LED
BLM_DOUT_DUOCOLOUR 2
# define the shift registers to which the anodes of the "second colour" (red) LEDs are connected
BLM_DOUT_L2_SR 5
BLM_DOUT_R2_SR 8
# set this to 1 if a button matrix is connected
BLM_BUTTONS_ENABLED 1
# set this to 1 if these buttons should only control the "step triggers" (gate, and other assigned triggers) - and no UI functions
BLM_BUTTONS_NO_UI 1
# optional (only useful in conjunction with the BLM):
# if 0: the GP buttons/LEDs are working as usual
# if 1: the GP buttons/LEDs always select the page items like if the MENU button is pressed,
# the GP LEDs show the selected page (if matching with any of these items)
BLM_GP_ALWAYS_SELECT_MENU_PAGE 0
# define the DIN shift registers to which the button matrix is connected
BLM_DIN_L_SR 7
BLM_DIN_R_SR 8
# Additional 8x8 BLM as used for Wilba's Frontpanel
# set to 1 to enable 8x8 BLM driver
BLM8X8_ENABLED 1
# to which shift register are the select lines connected?
# Allowed values: 0 to disable, 1..16 to assign shift register
BLM8X8_DOUT_CATHODES_SR 1
BLM8X8_DOUT_CATHODES_INV_MASK 0x00
# to which shift register are the LED anode lines connected?
BLM8X8_DOUT_LED_SR 2
# 0: no mapping of 8x8 LEDs
# 1: enable GP LED -> 8x8 matrix mapping for Wilba's MB-SEQ PCB
BLM8X8_DOUT_GP_MAPPING 1
# 8x8 matrix for misc. button functions
BLM8X8_DIN_SR 2
# Optional BPM digits
# set to 1 or 2 to enable the 3 optional BPM digits
# 0: BPM digits disabled
# 1: BPM digits with common cathode
# 2: BPM digits with common anode
BPM_DIGITS_ENABLED 1
# define the DOUT shift register to which the segments are connected (0=disabled)
BPM_DIGITS_SEGMENTS_SR 9
# define the DOUT SR and pin to which the common pins are connected
# we are counting from right to left
# Example: 140.5 BPM: (COMMON1 = .5, COMMON2=0., COMMON3=4, COMMON4=1)
# SR Pin
BPM_DIGITS_COMMON1_PIN 10 0
BPM_DIGITS_COMMON2_PIN 10 1
BPM_DIGITS_COMMON3_PIN 10 2
BPM_DIGITS_COMMON4_PIN 10 3
# Optional Step digits
# set to 1 or 2 to enable the 3 optional STEP digits
# 0: STEP digits disabled
# 1: STEP digits with common cathode
# 2: STEP digits with common anode
STEP_DIGITS_ENABLED 1
STEP_DIGITS_SEGMENTS_SR 9
# Example: Step 123: (COMMON1 = 3, COMMON2=2, COMMON3=1)
# SR Pin
STEP_DIGITS_COMMON1_PIN 10 4
STEP_DIGITS_COMMON2_PIN 10 5
STEP_DIGITS_COMMON3_PIN 10 6
# Optional LED Track Position Display
# See also http://www.midibox.org/dokuwiki/doku.php?id=tpd_pcb
# set to 1 or 2 to enable the relative track position display
# 0: TPD disabled
# 1: TPD enabled - columns are cathodes, rows are anodes
# 2: TPD enabled - columns are anodes, rows are cathodes
TPD_ENABLED 2
# define the DOUT shift register to which the columns are connected (0=disabled)
TPD_COLUMNS_SR_L 16
# for a 16x16 TPD: define the SR to which the right columns are connected (0=disabled, use only 8x8 TPD)
TPD_COLUMNS_SR_R 13
# define the DOUT shift register to which the green LED rows are connected (0=disabled)
TPD_ROWS_SR_GREEN_L 14
# define the DOUT shift register to which the right green LED rows are connected (0=disabled, use only 8x8 TPD)
TPD_ROWS_SR_GREEN_R 11
# define the DOUT shift register to which the red LED rows are connected (0=disabled)
TPD_ROWS_SR_RED_L 15
# define the DOUT shift register to which the right red LED rows are connected (0=disabled, use only 8x8 TPD)
TPD_ROWS_SR_RED_R 12
# CV and Gate/Trigger/Sync Setup
# AOUT interface now selected in CV Configuration Menu and stored in MBSEQ_GC.V4 file
# please scroll through the menu to find this page!
# the 8 CV gates can be assigned to a shift register (0=off, 1-32: number of shift register):
# - 1st CV Gate available at DOUT SR output D7
# - 2nd CV Gate available at DOUT SR output D6
# - 3rd CV Gate available at DOUT SR output D5
# - 8th CV Gate available at DOUT SR output D0
CV_GATE_SR1 18
# and DIN Clock Outputs can be assigned to a shift register as well (0=off, 1-32: number of shift register):
# D7..D0 will output individual clock or start/stop signals which can be configured in the CV configuration page
CLK_SR 20
# additional gate triggers are available on common digital output pins of the
# DOUT shift register chain - they are assigned to AOUT channel #16 (Note C-1, C#1, D-1, ...)
# define the shift registers which should be used here (each provides 8 gates)
# Note that SRs assigned to this function cannot be used as LED outputs (exclusive function)
# Allowed values: 1-32, 0 disables the function, all other values invalid and not allowed
DOUT_GATE_SR1 19
DOUT_GATE_SR2 0
DOUT_GATE_SR3 0
DOUT_GATE_SR4 0
DOUT_GATE_SR5 0
DOUT_GATE_SR6 0
DOUT_GATE_SR7 0
DOUT_GATE_SR8 0
# if set to 1, the additional DOUT "gates" will send 1mS pulses
# useful for analog drums
DOUT_1MS_TRIGGER 0
# should J5A/B/C outputs be enabled (0: no, 1: yes, 2: yes, but in open drain mode)?
# - the 6 first AOUT gates will be forwarded to J5A/B
# - the remaining last 2 AOUT gates are available at J5C.A10 and J5C.A11 (LPC17: J28.WS and J28.MCLK)
# - DIN sync clock will be forwarded to J5C:A0 (LPC17: J28.SDA)
# - DIN sync start/stop will be forwarded to J5C:A1 (LPC17: J28.SC)
# - if open drain mode enabled (option 2), external pull-ups have to be connected to J5 pins
# (advantage: pin levels can be pulled to 5V)
# NEVER USE THIS TOGETHER WITH ANALOG POTS - IT WILL CAUSE A SHORT CIRCUIT!
J5_ENABLED 1
# LED assignments to DOUT pins
# SR = 0: LED disabled
# SR = 1..23: directly forwarded to DOUT pin
# SR = M1..M8: forwarded to a 8x8 LED matrix
# Please note: due to historical reasons, pin 0-7
# are mirrored!
# Pin 0 = DOUT Pin D7
# Pin 1 = DOUT Pin D6
# Pin 2 = DOUT Pin D5
# Pin 7 = DOUT Pin D0
# SR Pin
LED_TRACK1 M7 2
LED_TRACK2 M7 1
LED_TRACK3 M5 2
LED_TRACK4 M5 1
# SR Pin
LED_PAR_LAYER_A M4 2
LED_PAR_LAYER_B M4 1
LED_PAR_LAYER_C M4 0
# SR Pin
LED_BEAT M1 1
LED_MEASURE 0 0
# SR Pin
LED_MIDI_IN_COMBINED 0 0
LED_MIDI_OUT_COMBINED 0 0
# SR Pin
LED_EDIT M5 3
LED_MUTE M6 3
LED_PATTERN M6 2
LED_SONG M7 3
# SR Pin
LED_SOLO M6 1
LED_FAST M6 0
LED_FAST2 0 0
LED_ALL M7 0
# SR Pin
LED_GROUP1 M8 3
LED_GROUP2 M8 2
LED_GROUP3 M8 1
LED_GROUP4 M8 0
# SR Pin
LED_TRG_LAYER_A M2 2
LED_TRG_LAYER_B M2 1
LED_TRG_LAYER_C M2 0
# SR Pin
LED_PLAY M1 3
LED_STOP M3 3
LED_PAUSE M2 3
LED_REW M3 2
LED_FWD M1 2
LED_LOOP 0 0
LED_FOLLOW 0 0
# SR Pin
LED_EXIT 0 0
LED_SELECT 17 4
LED_MENU 0 0
LED_BOOKMARK 0 0
LED_SCRUB 0 0
LED_METRONOME 0 0
LED_RECORD 0 0
LED_JAM_LIVE 0 0
LED_JAM_STEP 0 0
LED_LIVE 0 0
LED_UTILITY 0 0
LED_COPY 0 0
LED_PASTE 0 0
LED_CLEAR 0 0
LED_UNDO 0 0
LED_MOVE 0 0
LED_SCROLL 0 0
# SR Pin
LED_STEP_VIEW M3 1
LED_PAR_LAYER_SEL 0 0
LED_TRG_LAYER_SEL 0 0
LED_TRACK_SEL 0 0
# SR Pin
LED_TAP_TEMPO 0 0
LED_TEMPO_PRESET 0 0
LED_EXT_RESTART 0 0
# SR Pin
LED_DOWN 0 0
LED_UP 0 0
# SR Pin
LED_MIXER 0 0
# SR Pin
LED_TRACK_MODE 0 0
LED_TRACK_GROOVE 0 0
LED_TRACK_LENGTH 0 0
LED_TRACK_DIRECTION 0 0
LED_TRACK_MORPH 0 0
LED_TRACK_TRANSPOSE 0 0
LED_FX 0 0
# SR Pin
LED_MUTE_ALL_TRACKS 17 0
LED_MUTE_TRACK_LAYERS 0 0
LED_MUTE_ALL_TRACKS_AND_LAYERS 0 0
LED_UNMUTE_ALL_TRACKS 0 0
LED_UNMUTE_TRACK_LAYERS 0 0
LED_UNMUTE_ALL_TRACKS_AND_LAYERS 0 0
# Button assignments to DIN pins
# SR = 0: Button disabled
# SR = 1..23: directly triggered from DIN pin
# SR = M1..M8: triggered from a 8x8 button matrix
# SR Pin
BUTTON_DOWN M4 2
BUTTON_UP M4 3
BUTTON_LEFT 0 0
BUTTON_RIGHT 0 0
# SR Pin
BUTTON_SCRUB M4 4
BUTTON_METRONOME M4 5
BUTTON_TAP_TEMPO 0 0
BUTTON_JAM_LIVE 0 0
BUTTON_JAM_STEP 0 0
# SR Pin
BUTTON_STOP M3 5
BUTTON_PAUSE M2 4
BUTTON_PLAY M2 5
BUTTON_REW M3 4
BUTTON_FWD M1 4
BUTTON_LOOP 0 0
BUTTON_FOLLOW 0 0
# SR Pin
BUTTON_MENU M7 5
BUTTON_SELECT M8 4
BUTTON_EXIT M8 5
# SR Pin
BUTTON_TRACK1 M7 6
BUTTON_TRACK2 M7 7
BUTTON_TRACK3 M5 6
BUTTON_TRACK4 M5 7
# SR Pin
BUTTON_PAR_LAYER_A M4 6
BUTTON_PAR_LAYER_B M4 7
BUTTON_PAR_LAYER_C M3 6
# SR Pin
BUTTON_EDIT M5 3
BUTTON_MUTE M6 2
BUTTON_PATTERN M6 3
BUTTON_SONG M7 2
# SR Pin
BUTTON_SOLO M6 4
BUTTON_FAST M6 5
BUTTON_FAST2 9 2
BUTTON_ALL M7 4
# SR Pin
BUTTON_GP1 M5 0
BUTTON_GP2 M5 1
BUTTON_GP3 M6 0
BUTTON_GP4 M6 1
BUTTON_GP5 M7 0
BUTTON_GP6 M7 1
BUTTON_GP7 M8 0
BUTTON_GP8 M8 1
BUTTON_GP9 M4 0
BUTTON_GP10 M4 1
BUTTON_GP11 M3 0
BUTTON_GP12 M3 1
BUTTON_GP13 M2 0
BUTTON_GP14 M2 1
BUTTON_GP15 M1 0
BUTTON_GP16 M1 1
# SR Pin
BUTTON_GROUP1 M8 6
BUTTON_GROUP2 M8 7
BUTTON_GROUP3 M6 6
BUTTON_GROUP4 M6 7
# alternative (individual) track selection buttons
# LEDs have to be assigned to TRACKS_DOUT_L_SR and TRACKS_DOUT_R_SR
# SR Pin
BUTTON_DIRECT_TRACK1 0 0
BUTTON_DIRECT_TRACK2 0 0
BUTTON_DIRECT_TRACK3 0 0
BUTTON_DIRECT_TRACK4 0 0
BUTTON_DIRECT_TRACK5 0 0
BUTTON_DIRECT_TRACK6 0 0
BUTTON_DIRECT_TRACK7 0 0
BUTTON_DIRECT_TRACK8 0 0
BUTTON_DIRECT_TRACK9 0 0
BUTTON_DIRECT_TRACK10 0 0
BUTTON_DIRECT_TRACK11 0 0
BUTTON_DIRECT_TRACK12 0 0
BUTTON_DIRECT_TRACK13 0 0
BUTTON_DIRECT_TRACK14 0 0
BUTTON_DIRECT_TRACK15 0 0
BUTTON_DIRECT_TRACK16 0 0
# SR Pin
BUTTON_TRG_LAYER_A M2 6
BUTTON_TRG_LAYER_B M2 7
BUTTON_TRG_LAYER_C M1 6
# Following button functions are usually assigned to Fx
# buttons, or to dedicated (labeled) buttons
# In Wilba's frontpanel layout:
# F1 is located at SR M3 Pin 3
# F2 is located at SR M2 Pin 2
# F3 is located at SR M2 Pin 3
# F4 is located at SR M1 Pin 2
# and there are dedicated buttons for Copy/Paste/Clear/Utility/StepView
# SR Pin
BUTTON_TRACK_SEL M3 3
BUTTON_LIVE M2 2
BUTTON_RECORD M2 3
BUTTON_SAVE_ALL M1 2
# SR Pin
BUTTON_PAR_LAYER_SEL 0 0
BUTTON_TRG_LAYER_SEL 0 0
# SR Pin
BUTTON_UTILITY M3 2
BUTTON_COPY M7 3
BUTTON_PASTE M8 2
BUTTON_CLEAR M8 3
BUTTON_UNDO 0 0
BUTTON_MOVE 0 0
BUTTON_SCROLL 0 0
BUTTON_BOOKMARK 0 0
# SR Pin
BUTTON_STEP_VIEW M5 5
# SR Pin
BUTTON_EXT_RESTART 0 0
# SR Pin
BUTTON_MIXER 0 0
# SR Pin
BUTTON_SAVE 0 0
# SR Pin
BUTTON_PATTERN_RMX 0 0
# SR Pin
BUTTON_FOOTSWITCH 0 0
# SR Pin
BUTTON_ENC_BTN_FWD 0 0
# SR Pin
BUTTON_TRACK_MODE 0 0
BUTTON_TRACK_GROOVE 0 0
BUTTON_TRACK_LENGTH 0 0
BUTTON_TRACK_DIRECTION 0 0
BUTTON_TRACK_MORPH 0 0
BUTTON_TRACK_TRANSPOSE 0 0
BUTTON_FX 0 0
BUTTON_TEMPO_PRESET 0 0
# SR Pin
BUTTON_MUTE_ALL_TRACKS 0 0
BUTTON_MUTE_TRACK_LAYERS 0 0
BUTTON_MUTE_ALL_TRACKS_AND_LAYERS 0 0
BUTTON_UNMUTE_ALL_TRACKS 0 0
BUTTON_UNMUTE_TRACK_LAYERS 0 0
BUTTON_UNMUTE_ALL_TRACKS_AND_LAYERS 0 0
# alternative (individual) bookmark buttons
# no LEDs available!
# SR Pin
BUTTON_DIRECT_BOOKMARK1 0 0
BUTTON_DIRECT_BOOKMARK2 0 0
BUTTON_DIRECT_BOOKMARK3 0 0
BUTTON_DIRECT_BOOKMARK4 0 0
BUTTON_DIRECT_BOOKMARK5 0 0
BUTTON_DIRECT_BOOKMARK6 0 0
BUTTON_DIRECT_BOOKMARK7 0 0
BUTTON_DIRECT_BOOKMARK8 0 0
BUTTON_DIRECT_BOOKMARK9 0 0
BUTTON_DIRECT_BOOKMARK10 0 0
BUTTON_DIRECT_BOOKMARK11 0 0
BUTTON_DIRECT_BOOKMARK12 0 0
BUTTON_DIRECT_BOOKMARK13 0 0
BUTTON_DIRECT_BOOKMARK14 0 0
BUTTON_DIRECT_BOOKMARK15 0 0
BUTTON_DIRECT_BOOKMARK16 0 0
# Button behaviour
# 0: active mode as long as button pressed
# 1: pressing button toggles the mode
BUTTON_BEH_FAST 1
BUTTON_BEH_FAST2 0
BUTTON_BEH_ALL 1
BUTTON_BEH_SOLO 1
BUTTON_BEH_METRONOME 1
BUTTON_BEH_LOOP 1
BUTTON_BEH_FOLLOW 1
BUTTON_BEH_SCRUB 0
BUTTON_BEH_MENU 0
BUTTON_BEH_BOOKMARK 1
BUTTON_BEH_STEP_VIEW 0
BUTTON_BEH_TRG_LAYER 0
BUTTON_BEH_PAR_LAYER 0
BUTTON_BEH_TRACK_SEL 0
BUTTON_BEH_TEMPO_PRESET 0
# Special Behaviour of ALL button
# 0: only parameter layers are modified by ALL function
# 1: trigger and parameter layers are modified by ALL function
BUTTON_BEH_ALL_WITH_TRIGGERS 0
# Encoder Functions
# SR = 0: encoder disabled
# SR = 1..16: DIN assignment
# Types: NON_DETENTED, DETENTED1, DETENTED2, DETENTED3, DETENTED4, DETENTED5
# SR Pin Type
ENC_DATAWHEEL 6 2 DETENTED3
# the speed value for the datawheel which is used when the "FAST" button is activated:
ENC_DATAWHEEL_FAST_SPEED 3
# SR Pin Type
ENC_GP1 1 6 DETENTED3
ENC_GP2 1 4 DETENTED3
ENC_GP3 1 2 DETENTED3
ENC_GP4 1 0 DETENTED3
ENC_GP5 3 6 DETENTED3
ENC_GP6 3 4 DETENTED3
ENC_GP7 3 2 DETENTED3
ENC_GP8 3 0 DETENTED3
ENC_GP9 4 6 DETENTED3
ENC_GP10 4 4 DETENTED3
ENC_GP11 4 2 DETENTED3
ENC_GP12 4 0 DETENTED3
ENC_GP13 5 6 DETENTED3
ENC_GP14 5 4 DETENTED3
ENC_GP15 5 2 DETENTED3
ENC_GP16 5 0 DETENTED3
# the speed value for GP encoders which is used when the "FAST" button is activated:
ENC_GP_FAST_SPEED 3
# Auto FAST mode: if a layer is assigned to velocity or CC, the fast button will be automatically
# enabled - in other cases (e.g. Note or Length), the fast button will be automatically disabled
ENC_AUTO_FAST 1
# optional BPM encoder
# SR Pin Type
ENC_BPM 9 1 DETENTED3
# the speed value for the BPM encoder which is used when the "FAST" function is activated
ENC_BPM_FAST_SPEED 3
