12 -
3090's Achievements
i will follow your suggestion to try the testmode in the new firmaware, and will give feedback about it. :smile: Best Regards 3090
Dear Thorsten, I own a MB6582, that i bought, not build. I know the current behave and it is improvable, as now is not well usable. I wrote about the pot behave like example. Best Regards 3090
Ciao Thorsten, I am interested in this variant. The suggestion i can give to improve the behave of MBSID are the followings: -Values of 127 instead 255 -Fast Response turning the knobs: to easily edit and cover the whole range of value in one turn of the encoder: 0 - 127 From my experience, i feel good using the "Relative Mode" and the "Jump Mode" in the DSI Poly Evolver. For explain i paste from the Poly Evolver Keyboard Manual Addendum: The latest version of the Poly Evolver Keyboard operating system adds an item, PotMode, to the Global parameters that is not documented in the manual. (See page 18 of the Operation Manual for more information about the Global param- eters.) PotMode: Relative (default), Passthru, Jump – On the latest version of the Poly Evolver Keyboard, many of the 78 front panel controls are potentiometers or “pots.†There are three pot modes to determine how the synth reacts when the related parameters are edited. When set to Relative, changes are relative to the stored setting. In Relative mode, the full value range is not available until either the minimum or maximum value and the respective lower or upper limit of the pot’s travel is reached. For example, the Resonance parameter has a value range of 0 to 127. Let’s say the physical position of the Resonance pot is the equivalent of a value of 100. If you switch to a program that has a stored Resonance setting of 63 and turn the pot all the way up, it will only go to 90. To get to the maximum value of 127, you first have to turn down until the value is at the other extreme and the pot is at the limit of its travel (in this case, 0 and fully counter-clockwise, respec- tively). In Passthru mode, turning the pot has no effect until after the edited value equals the preset value (that is, until the edited value “passes through†the stored value). Jump mode uses an absolute value based upon the position of the pot when edited: turn a pot and the value jumps immediately from the stored value to the edited value.When set to Relative, changes are relative to the stored setting. In Relative mode, the full value range is not available until either the minimum or maximum value and the respective lower or upper limit of the pot’s travel is reached. i hope to be helpful Best Regards from Italy 3090
:smile:
Hello Scifo, I have the same situation with CUT OFF of my MB.... Did you change something? If yes i am interested. Best Regards 3090
i like Ear Acid !!
I like the sounds ! Good!
Hello Everybody, As i think everybody here love music, I would like to know, some songs you know, "famous" / "mainstream" songs done with Chip Sound.... except the ones Timbaland "did".....do it - nelly furtado and ayo technologies -50 cents feat justin timberlake What he did bad: don't give any royalties to the original composers: need pay the rights... maybe later... http://en.wikipedia.org/wiki/Timbaland_plagiarism_controversy but how he did ,merged the chip sound in the hip hop... he did good artistic choice He sampled underground sound of the 80's, as the most hip hop producers have sampled the 70's funky Courious to know works of producers i never heard Best Regards and Respect to Chip Sound 3090
- Songs
- Chip Sound
(and 1 more)
Tagged with:
Hello Guys, Iam not goog at soldering, neither i am thinking to learn it: it is not my story. But i love that small black instruments Wilba did. I would buy a MB-6582 Complete and Working. I am in the north of Italy. Does someone have one ? Thanks you all 3090
