Hi, I'm new here ;-)
For more than a year I own the components and boards for the V4L. Last Saturday, I finally started the project. The first step was to burn the bootloader. I had a lot of problems with the current version of the IDE. After a search in the forum, the solution was found: an older version of the IDE. Now, I will continue with the soldering. Also, I just am thinking about a suitable case. Because I don't like acryl glas cases, I plan to buy a desktop housing (ABS with aluminium front panel). Then I will replace the alu panel with a customized Schaeffer front panel. Question: Are there already files available which I can import into the Schaeffer Front Panel Designer as base for my own creation?
Thanks in advance,
Tom
