Zam
Members-
Posts
625 -
Joined
Last visited
Days Won
26
Content Type
Profiles
Forums
Blogs
Gallery
Everything posted by Zam
I'm just thinking about another strange thing I don't understand. When I hit slash and backslash button in MF Tool my two fader don't go to the same position. I swap the fader at J2 and it don't folow, but stay at the same PIC output??? Zam
my lovely Studer 289 :smile: -------------- Thorsten, what you could provide sound good to me, i think it deserve a try. As i say previously I'm new to programming, I already install X11 on my laptop, and will instal dev tool, I need time to be efficient at this task (learning the tools), but solving this problem and find the good solution could really open a new world for all ple like me using old desk, I already have two friend/studer x89 owner folowing my modification. I will look closer and download the tools. I keep you informed about this. I have a look at my noise frequency, it's 1K (and harmonics 2k 4K etc...) so it's the 1ms trigger for sure. I wish It will be some subharmonic artefact I can filter, but it's not, and it's in the audio range :( I put a 100n across 5V and 0v at the J2 (like in MF V1) but without success, I will try your suggestion. I have to investigate more (disconnecting the touchsens ribbon sound worst...), it's also could be a fader design issue, audio, servo, and touch track are close... Zam
vidéo :smile: https://dl.dropboxusercontent.com/u/95767560/IMG_0265.mov
Hello some update I connect and run the two fader I show before, and perform more test and calibration setup Good new is now I can say only one hard coded(fixed) table for all fader is need, fader tolerance are good, no need for individual correction, and I'm using cheap ALPS, will be better with P&G or TKD I still have problem regarding noise. Now I connect each 0v servo to individual module enclosure, it's better for motor noise in audio, but I wish It could be even better. Grounding and ref voltage is not easy when interfacing digital device in a large analogue desk, I have to try different grounding. Other one, way louder and problematic, is noise produced by touch sensor. When I touch the caps it become quieter, and close to silent if I touch my console frame at the same time. If I set sensor sensitivity to 1 (minimum) noise disappear, but fader is not usable at this setting. I don't record frequency yet, but sound like fraction of the digital clock. What kind of signal is use for touchsensor? just DC? do you think I can filter this with some LPF to avoid HF leaking here? regrading fader move i'm not 100% happy with settings I try, I like the fader fast when I read a square automation. But I can't in the mean time stop the fader knob to have crazy shake when reading a slow sin wave automation. Zam
No I don't forget your idea :smile: at the end I need button and led so I need a core system. The 0, -5 , -10 etc... have direct and linear correlation with DAW fader pitch bend value at one side, but maybe you talk about "interpolation" between this points at the other side? which is not linear but like one of the graph I post before? ----- All this is just to have an efficient grouping fader possibility that track well at the analogue side...maybe i'm too ambitious :sad: and don't have the skill to build (program) what I want. Or the system can't handle this in any way? is that you saying? I understand you are not interested on this, and by the way, I don't buy you a beer :tongue: Best Zam
hello Thorsten I have to admit I'm little lost with this, but in the mean time I think I understand what you say. When you say flash memory you mean the SD card with core system (for the moment I only run MF board standalone), or some memory available in the PIC I have now? I think 10bit is enough for motor position, it's less than 1/10mm for 100mm fader, my hand never do such repositioning when I recall a mix to the desk :smile: So your option is a fixed table, but previously set for each fader log characteristic according to measurement i made like previously in this topic, right? So each time i want to recalibrate the fader (saying with time the resistive track characteristic change) I have to do measurement again, and compile new table for each fader? How it will be complicated to add a new function in the MF tool (like a new tag or window) with a matrix or table where you can set the value for 12 point (0-5-10-15-20-25-30-40-50-60-70-inf). The table have only to be adjusted at one side. The fader position pitchbend value in the DAW will never change, except if different DAW have different log curve for the fader? Or better, a learn command! when you clic, it record the motor fader position in the table, so a routine calibration (say each month) take less than 10 min Just send a test tone in all channel set all fader at top--> one clic--> all "0dB" data are stored (usually 1023) set all fader at -5 (real dB analogue attenuation read at my peak meter)--> one clic--> all "-5dB" data stored set all fader at -10 etc... maybe I'm dreaming ? by the way I attach 2 pict of my work :smile: second prototype have button and led, but it's just for mechanical test. Also need nice front panel... Best Zam
Hello Thorsten Tks for explanation yes I'm on Mac, G5 10.3.8 running Digital performer, i'm not realy up-to-date regarding digital side of my studio... I have a laptop whitebook running 10.6.8 for everything else including MIOS for setting up my fader proto I have no clue on software programming an compilation...last "programming" was at school on PB15... 20 years ago :p But I can learn! Is your programme allowing adjustment for each fader, in something like a table or matrix, or is it a fixed value translating both way all pitch bend info ? Zam I go to look google "how to compile" and i'm back :)
hey here it is first graph: X is dB reduction Y is pitch bend value red is the value read in MIOS according to DAW position fader blue is the value read in MIOS when I position my fader at real analogue attenuation I want the 2 curves to be the same :smile: second graph: X DAW fader pitch bend value Y analogue fader pitch bend value each point take for the same attenuation in dB (0-5-10-15-20-25-30-40-50-60-70-inf) I want the line to be a straight one :smile: ----------------------- let take the example at 10dB attenuation (ref to full top position) DAW send a PB value of 1252, but at this value the motor driver don't put my analogue fader at 10dB attenuation, the fader need a PB value of 2576 to achieve this. So, I need to translate value 1252 to 2576 at 20dB I need to translate -2480 to -1696 etc... Zam
hello Novski Off course I use the MF Tool !!! I don't know how i can explain thins in other way :( DAW fader log scale and analogue console log track are not the same log, and i need them to match. The -18dBfs is a studio reference, nothing to do here. The 0dB attenuation is always on the top of a resistor divider, but most of the manufacturer put a 0 ref label at -10dB attenuation and put a 10dB buffer after the fader so unity gain are not on top what I need is a solution to convert DAW fader pitchbend value to another physical fader position on the MF_NG side example: pitchbend value 0 set the fader half way, 50mm from top in a 100mm fader. But how can I do this 0 value put the fader 25mm from top? I go to make some measurement and tab and i'm back :smile: Zam
mmm... I have some read in the manual did MAP command be a solution? I also see the "curve" setup in the CV tool, i think it's something like that I need, but with a custom curve, that i can adjust...
Hello First prototype is running, i will share pict soon Lot of thing to check like motor electronic noise in my analogue audio path, i was able to reduce it with proper grounding, but still there when not touching the sense fader caps, anyway it's close to my Studer noise floor, should not be an issue as noise level is function of the fader position, and in real life if fader is up there is loud audio passing trough (min 60 dB over noise floor) Second issue is mechanical noise, I'm not free regarding mechanical integration as i have to make the fader fit an existing frame/design, i have huge resonance in the frame and aluminium structure/pate, my first proto is not good i have to rethink the mechanic :) and maybe put some rubber/absorber somewhere, I use ALPS now, maybe it will be better with TKD fader Also the regulator run HOT Now some question! Is it possible to rescale and change the response curve of the fader physical position? The "problem" is that the DAW reading fader value don't match my real log audio response, it's not a problem when using a single fader, I don't care if I have offset or non matching boost/attenuation reading the value. BUT if I group some fader the relative attenuation between audio channel is not linear For example: DAW side, I have a kick on channel 1 at 0dB and a snare on channel 2 at -10dB that's 10 dB differential, both channel in same "drum" group Now i move the kick 5 dB down given to me -5dB for kick, the snare fader follow and set the fader value at -15, relative power still matched, 10dB On the analogue side, Kick are initially at top pos (0dB) and move down to -2cm position (say it's a real attenuation of 8dB) The snare are initially at -2cm position ( -8dB) and move to -4cm position giving 20 dB of attenuation. My relative power change from 8dB (0-8) to 12 dB (8-20). My gain structure is broken and the snare is (relative) 4dB quieter How can I manage that ? Zam PS: I start this project 2 month ago, and there will be a long time left before I solve everything, but I have to say your system is addictive and open a new world to me, THANKS !!!
tks Novski to pointing me at this, I will look better an learn MIOS I ask this because i think i will print my physical fader automation in an aux send as i want to keep signal to the DAW mute/solo and main fader trough analogue output, then to each individual desk voices where my passive motorised audio fader is. I don't need to implement physical button flip function, I will never flip, as I pass audio I don't want my fader to read or write another data I attach my pic again, seem like it disappear in both post when I edit the double post... I look at this Mec switches some days ago, and now I don't remember why I don't try it in my design :question: Zam
hello Here is a preview of my "moving fader ! Anyway 3D rendering is just for fun, it's more to see how to put all i want in my existing frame modules I'm already waiting for my MF board to perform the first test I'm little disappointed about switches i find, there is so nice illuminated NKK or Omron, but none of them have pinout compatible with 2.5 or 2.54 pitch For the moment the candidate are round ITT schadow with separated LED, and i keep the original illuminated EAO for the PFL I have question regarding HUI or MCU mode with the MF_NG, is it possible to "flip" the destination (aux send for example) form MIOS? Zam
mmm... double post :rofl:
Hoooooo !!!! Tks Peter! didn't see this, my order is in process :happy: Zam
Hey all I order MF_NG and a PIC from Smash TV 10 days ago, I read about possible delay, no problem at all I'm just wondering if it's normal I don't receive any confirmation email about my order ? Zam
you want to light both LED at same time with fast pulse ? I just ask because you will have yellow colour :rolleyes:
hey Novsky actually my VCA (studer modular card around DBX/THAT) are set to 1V/40dB and are drived by a DC coupled soundcard in the +1/-2,5V range to achieve +40/-100 dB of gain. If I want a moving fader (automated by DAW with HUI) I need one servo track, the other track will be the one driving the CV input of the VCA. I not sure using the same DC signal for both function will be a good thing ? even if I do a converter/offset circuit from 0/-5 to +1/-2,5V (or +4/-10v, i have different CV sensitivities jumper) But maybe it's something to try :) Anyway the main goal is to keep the signal passive, that's the first thing I want to test. VCA stay in my mind just because of my stereo channel, and accuracy i will find (or not) by using two audio fader. TKD offer me stereo audio track + servo and touch, but I'm not sure it is in stock now. Zam
Tks ilmenator, I already read this, but need a confirmation. ALPS dual track (lin+log) are on the way. If some one have an idea where to find dual linear track (servo+VCA) ? i don't find yet... Zam
Hello I have a dumb question... Are the MF_NG modules able to work "stand-alone" or do I need a core system in any case? Zam
yes...have to test, not an easy mechanical integration, I have room in the fader modules to put new fader and led/button, but not easy to leave pcb close to the front (fader) of the 8 unit subframe (5 in total), at best i can dispatch on the back of the console. Zam
Hey Novski Tks for reply When you say pre built you mean already soldered? I may be interested, depending of your price. Let me know :) Are the firmware already printed? I just have to install the OS? The advantage of the kit is that i don't have to pay soldering job, and I also have just component I need and extra connector and ribbon in low quantities, Otherwise I have to order component in larger quantities (mostly on RS for me), for the prototype i don't need to many. Your version is the pictures above on this page? You change the connector layout to have single ribbon with servo and touch for each fader? I soon made a list of what I have to test. for example what is the max length of ribbon between PCB and fader without losing data, my console frame is "large" and final project (if possible) will have all card in a 19" rack. Zam
Hello I'm new here, some pple on groupdiy point me on this forum regarding automated fader I have a look at the main website, also here in the forum. I think i find the correct place :happy: My "project" is basically to replace my diy patchable VCA automation on my hold discrete mixing desk. I have a long read and I understand that all the ppl prototyping/building controller around the MF board set it up with servo track fader only (for DAW control) My goal is tu use dual track (log audio+lin servo) to perform a passive audio automated fader, like "flying fader", "moving fader system" or more recent API 1608 and neve "swift mix" in the 5088. I find ALPS RSA0 series with servo and audio track that will be good for prototype as your guys already use this series with success right? I don't find K series yet or P&G8000 with dual track, but if someone have input? i want to test different hi qualities fader. RSA0 are "low cost" and audio spec are not optimal for my use especially the audio taper tolerance. I want to buy a MF_NG kit, i saw them in America trough midibox-shop, nothing in EU for this? For what I understand i need to print firmware to the PIC, i'm not able to do it, so I have to ask when I buy it, I just have no idea about "PIC ID header" I need. After that I can access all other setup/calibration via MIDI with MIOS right? I don't understand everything about software right now but will learn. MF_NG work in stand alone right? in need nothing more for prototype (except PSU) Enough question for the moment, i just let you know my final goal 32 motor fader controlled by DAW fader 32 rec automation push button + 32 led status 32 play automation push button + 32 led status 32 automation mode select push button with led status (have to define how many mode i need...) 32 relay paralleling my mute switch (actually driving a FET post fader) If possible with more core system there will be 12 more fader pack (44 total) for master and aux return I'm not talking about mechanical integration but I want to keep it modular, as the console is. By the way it's a 70' Studer 289 Tks in advance. The system your developing is so exciting :hyper: Zam
